Active IQ and AutoSupport Discussions
Autosupport Issue
chadharter
I'm having an odd issue.  I have a FAS2040 cluster.  Controller1 will not send out autosupport information and returns the following error in the log when a test is ran:
Severity  Event  Triggerred  Message
info   asup.smtp.retry  Wed Mar  2 19:17:20 CST  AutoSupport mail (HA Group Notification from netapp1 (USER_TRIGGERED (Test Autosupport)) INFO) was not sent for host (0). The system will retry later to send the message
warning   asup.smtp.fail  Wed Mar  2 19:17:20 CST  AutoSupport mail to 192.168.0.13 failed (Failed to transmit smtp asup) for message: HA Group Notification from netapp1 (USER_TRIGGERED (Test Autosupport)) INFO
info   callhome.invoke  Wed Mar  2 19:16:56 CST  Call home for USER_TRIGGERED (Test Autosupport)
I can do the same test from Controller2 and it works fine.  Both controllers have identical Autosupport settings.
Anyone seen this behavior before?  Any help would be greatly appreciated.  I've wasted 8 hours today trying to get Netapp Support to help me as I also had this same controller failover for an unexplained reason today.  Not sure if it's a hardware problem or the two are related.
Thanks in advance for any feedback.
-Chad
9 REPLIES 9
rodrigon
Hi Chad,
It's sounds like Rely at Mail Server. Was controller1 allowed for rely at e-mail server?
See you,
Nasc
NetApp - Enjoy it!
thmaine
I had the same problem. I was using an iis smtp server to relay the mail. My autosupport mails had grown larger they the relay server would allow. You can also turn logging on and see what is being thrown.
Thanks
Thomas
chadharter
The autosupport test is a very small email so I don't think size is the issue.  I have been assured that the mail relay is allowing the mail from both controllers.
thmaine
I though the same thing. Its worth investigating the smtp logs on the relay server. that is how I found the issue. If you are sure the autosupport is pointed to the correct relay server and it can reach it then the problem is mostly like on the relay server side.
Thomas Maine
Technical Services Manager
Bond International Software, Inc.
chadharter
How do you enable logging for autosupport?
thmaine
The logging I was referring too was the smtp logging on your relay server., the message you already posted is just about I was able to get out of the netapp logs.
Thomas Maine
matej
We are facing with the same issues. The strange behavior is faced not only on one controller. Lots of issues are related with DoT 8.x. There is a common issues if you use Filer View to send Autosupport  - nothing happens, but if you generate message using CLI it works fine. Has anybody ever seen that?
-Matej-
huyphong77
It seems that ASUP use the BMC interface to send. Check your BMC interface ?
chadharter
I finally figured this out late last night.  Here's the deal.
The mailhost was configured to do a reverse lookup of the IP address that the SMTP conversation comes from.  If it can resolve that name, it allowed the mail to pass.  If it could not reverse lookup based on that IP source, it denied it.  The Netapp was using vif0 to send the autosupport messages.  It just so happened that I had a DNS name setup for one controller's vif0 interface (the one that was working), but not the other.  I'm using vlans and I really didn't have the need to setup a DNS name for vif0 on the controller in question, until now!
Anyway, bottom line is that I needed to make sure that the IP address of the interface vif0 resolves back to a name.  It's a security setting in the SMTP relay host.  I finally figured this out by using the packet capture feature in Ontap and analyzing through Wireshark.  Hope this helps somebody else out there.
Thanks for all of the replies.
-Chad
