Active IQ and AutoSupport Discussions
Autosupport for C-Mode
nachin
I am new to clustered OnTap. I used to use autosupport to check system configurations of my 7-Mode controllers. The information is just rich and helpful.
However, system configurations are vServer-based in C-Mode controllers. How can I check the settings such as
network port show?
Any replication would be appreciated.
3 REPLIES 3
AGUMADAVALLI
use the "my autosupport" from now.netapp.com to browse to node or SVM or cluster specific details.
thank you,
AK G
asulliva
If you are getting a full AutoSupport from your nodes, I believe the data you want is in the cdb-net-port.xml and cdb-net-vifs.xml files.  If you're looking for LIF information, it's in the network-interface.xml file.
Note that AutoSupport is sent on a per-node basis, not cluster.  So each node will only report it's own data, and all of them together equates to the cluster.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
