Active IQ and AutoSupport Discussions
Issue with netbooting a FSA 2040 filer
cwnetappnewbie
Unable to netboot a FAS 2040 filer (error message in file attached)
It is part of a HA cluster that was partly upgraded, the 1st node was upgraded to ontap 8.1 7-Mode, while the 2nd node was accidentaly rebooted prior to been upgraded and hae not been able to get it back up since
Any recommendations on how to get it back up will be appreciated (fortuantely it is not in production)
1 ACCEPTED SOLUTION
cwnetappnewbie
Thanks, was able to resolve it,
appears the windows server I was using as to host the netboot files was the issue,
Used the partnet filer and was able to netboot correctly
2 REPLIES 2
hariprak
Hi,
Hope this helps, https://kb.netapp.com/support/s/article/NETBOOT-FAQS
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
cwnetappnewbie
