Active IQ and AutoSupport Discussions
autosupport.content difference between option minimal and complete
pravinb
Hi,
     We were enabling autosupport for our filers recently and security team wanted to keep the autosupport content option to minimal. I could see from the docs that the option minimal will omit sections and values that might be considered sensitive information and reduce the amount of information sent. Choosing minimal greatly affects the level of support you can receive from global support since we do not have all the configuration details available in autosupport.
Given below are the details of command outputs that autsupport sends.
  • Items marked with an asterisk (*) are suppressed in the AutoSupport.content Minimal format.
  • Items marked with two asterisks (**) are partially displayed in the AutoSupport.content Minimal format.
aggr status
aggr status -v
availtime
cf monitor all
cf rsrctbl
cf timers
cifs domaininfo *
cifs sessions*
cifs sessions -t -c
cifs shares*
cifs shares -t
cifs stat
df
df -A
df -i
df -r
disk show -u
disk shm_stats ata
dns info
ems event status**
ems log status*
environment status all
fcp config
fcp show adapter
fcp show adapter -v
fcp show initiator
fcp show initiator -v
fcp stats
fcp status -v
fcstat device_map
fcstat fcal_stats
fcstat link_stats
fpolicy
httpstat
ic stats error -v
ic stats performance
ifconfig -a*
ifstat -a**
igroup show
iscsi config
iscsi show adapter
iscsi show   initiator
iscsi stats
iscsi status
license
lun config_check -s
lun show
lun show -v
lun stats -a -o
nbtstat -c *
netstat -s
nfsstat -c
nfsstat -d
nis info*
options**
perf report -t
qtree status -i -v
raid_config info showfdr
snap list -n -A
snap reserve
snap reserve -A
snap sched
snapmirror destinations -s
snapmirror status -l
snapvault destinations
snapvault snap sched
snapvault status -c
snapvault status -l
snet status -v
storage show adapter -a
storage show disk -a
storage show fabric
storage show hub -a
storage show initiators -a
storage show port
storage show switch
sysconfig -a**
sysconfig -c
sysconfig -d
sysconfig -D
sysconfig -r
version -b
vfiler status -a
viadmin list -v
vif status*
vlan stat*
vol media_scrub status -v
vol scrub status -v
vol status
vol status -c
vol status -l*
vol status -v
vscan
vscan scanners *
vscan options
wafl catalog stats -lp
wafl swarmstats
  • Checksum status
  • Error-Correcting Code (ECC) memory scrubber statistics
  • The following information if active/active configuration is licensed:**
  • Contents of the following /etc directory files
    • /etc/messages (to last WEEKLY_LOG event)**
    • /etc/log/ems files (to last WEEKLY_LOG event) (optional)**
    • /etc/serialnum file
    • /etc/rc file*
    • /etc/nsswitch.cong file*
    • /etc/exports file*
    • /etc/snapmirror.allow file (if the SnapMirror license is enabled)*
    • /etc/snapmirror.conf file (if the SnapMirror license is enabled)*
    • /etc/syslog.conf file*
    • /etc/hosts file*
  • Registry information
  • Usage information*
  • Service statistics
  • Boot time statistics*
  • NVLOG statistics*
  • WAFL check log
  • Modified configurations
  • X-header information
  • FlashCard information
Is there any way where we can set the autosupport.content option to complete and yet filter out only few of the details that the security team considers sensitive instead of not sending a whole bunch of data?
Thanks & regards,
Pravin Bas
1 ACCEPTED SOLUTION
andris
I can confirm that selective filtering of the complete AutoSupport is not a currently available feature. Note: AutoSupport will have enhancements in this area in future releases of Data ONTAP.
-Andris
3 REPLIES 3
kawai
I don't believe ASUP has this capability but maybe someone more knowledgeable than I am can confirm.
andris
-Andris
bkicken
Hi Andris,
Is this filtering feature available now in Ontap 8.0.1 ?
If not, do you have any indication when this feature will be available?
thanks
Ben
