Additional Virtualization Discussions
Using Flexclone and RCU for Production use
ajay_nabh
Hi Guys
I wanted to use RCU to build citrix presentation servers for production use, do you guys think that it is a good idea to use RCU/Flexclone for Production server? what is official line by NetApp?
if you guys please advise your suggestions and docs to read will be very helpful
thanks
Ajay
1 ACCEPTED SOLUTION
forgette
In addition, here is a link to the technical report describing the technology and use cases:
http://www.netapp.com/us/library/technical-reports/tr-3742.html
8 REPLIES 8
prakash_aviva
Don't know much, but found a community thread.....
http://communities.netapp.com/message/8584#8584
forgette
Absolutely.  The VMs created by RCU will create pre-deduplicated virtual hard drives.  The result is not only capacity savings, but speed improvements as well.  This is because the NetApp storage controller cache is dedup aware.
ajay_nabh
THanks Mohit and Eric
Question for you Eric, this NetApps official line as I need to present some sort of doc to my boss where it says in black and white? so far all I found was can be used in Lab, development etc!
thanks in anticipation
Ajay
forgette
Ajay,
Chris lays it out in this video...
http://il.youtube.com/watch?v=eDCT1kHNlig
I've asked some folks to provide more collateral for you as well.
In the mean time, here are some answers:
NetApp dedup is appropriate for production virtual server workloads (in fact it will boost performance).
NetApp file level FlexClone creates "pre-deduplicated" vmdk files.
The RCU leverages NetApp file level FlexClone to create space efficient virtual machine clones.
Hope this helps,
-Eric
ajay_nabh
Hi Eric
Thanks a lot for doing this much effort.
appreciate it
Ajay
vstewart
Yes - Please use VMs deployed via RCU (FlexClone) for produciton use cases.
You should understand that Data ONTAP is a pointer based storage array.  Snapshot backups, File Clones, & Data Deduplicaiton are all based on the same technology.  Pointers for backup, zero cost provisioning, and storage efficencies over the life cycle of a data set.
If you have any additional thoughts arounf the use of RCU, you will find loads of discussion and comments here:
http://blogs.netapp.com/virtualstorageguy/
Cheers,
Vaughn
forgette
ajay_nabh
Hi Eric
do you have any case studies which can show RCU/FlexClone works well with heavily utilised VMs like Citrix Servers?  All I hear about is test and dev environment, also VDI environment. I trialled it out and seems to be wonderful technology
Cheers
Ajay
