AFF
AF8080 Architecture Document
NTA1201
Hello,
I'm new in NETAPP world!
Is someone willing to share with me links where I can find architecture docs or slides?
In http://support.netapp.com/documentation/productsatoz/index.html there is only setup and install guides but not concept of AFF8080.
Thx.
Best regards.
NTA.
1 ACCEPTED SOLUTION
AlexDawson
Hardware block diagrams for the FAS8080 platform are only available under NDA. Please contact your local NetApp field office for details.
Is there any specific you wish to know? ie, how certain failures are protected against? or just an over-all block diagram?
7 REPLIES 7
Sahana
Hi,
Am not sure which information you are looking for. However here are some docs on AFF and ONTAP 9 concepts:
https://library.netapp.com/ecm/ecm_download_file/ECMLP2495116
https://library.netapp.com/ecm/ecm_download_file/ECMLP2615331
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
NTA1201
Hi,
Thx it's geat information already but I would like to have the hardwae architecture or concept documents of AFF8080.
Except setup or install guide or datasheet, nothing found!
Thx.
NTA
Sahana
Hi,
Found this data sheet for AFF: http://www.netapp.in/media/ds-3582.pdf
AlexDawson
NTA1201
Hi Alex,
Thx for your answer.
No no specific question but an overview of block diagram and technology concept.
Can yo pls tell ma what's NDA means?
Best regards.
NTA
AlexDawson
NDA = Non-Disclosure Agreement.
They're basically custom engineered X86_64 uEFI systems - Intel Sandy Bridge, with a controller battery backup/memory de-stage to SSD, embedded USB key for boot image. Our operating system is ONTAP, which runs on top of FreeBSD.
If you have any specific questions, we might be able to help - otherwise, it's information we don't put out in a public document
NTA1201
Hi Alex,
Thx for the info, I will contact local NetApp field office for details.
Best regards.
Nordin.
