Video - Snap Creator 4.1 - Using META_DATA_VOLUMES
by NetApp on ‎2014-04-11 05:09 AM
Application consistent backup copies are important to many users of Snap Creator.
With certain applications or databases, when you put the database into a consistent state information about the database is written to another location so that it can be written to the database once it is returned to normal mode.
This second database should not have a Snapshot copy taken of it while the database in a consistent state, because the database is writing to that location.
You must take a Snapshot copy once the database has been returned to normal mode to have a full set of data for recovery purposes.
Snap Creator is able to identify volumes as a META_DATA_VOLUME.
This tells Snap Creator that the volumes identified as a META_DATA_VOLUME should have a Snapshot copy taken after the unquiesce operation has completed.
This video walks through this information as shows you how to configure a volume as a META_DATA_VOLUME.
This change cannot be made via the GUI - the config file needs to be edited through a text editor.
This video builds on the configuration file created in
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
