Data Backup and Recovery
SMO Clone mount problem
kiyomits
IHAC occurred SMO Problem.
If data LUN is full, smo fails to restore mount to another server.
After make volume clone, because smo try to re-use tempdb file in data LUN.
But data LUN is full, so restore operation is failed. Like attached files.
Can you tell us how to backup when data lun is full.
1 ACCEPTED SOLUTION
stanton
In the smo.config file add the parameter:
clone.ignore.temp.file.creation=TRUE
You will have to manually create the temp file after the clone is complete (or in the SQL section of the clonespec file).
1 REPLY 1
stanton
