Data Backup and Recovery
XenServer Restore Issue
vMarkus_K
Hi,
I`am running a test XenServer 6.0.2 witt 2 VMs:
CentOS
W2K9R2
SC 3.6.0.1 is uses on Windows 2008 R2
Backup seems to be working Fine (without error). But no restore is possible.
For me it semms to be a metadata Problem.
NFS Tree, including snapshot:
[root@localhost mnt]# tree -a
+-- 8a530fff-0047-ddde-ebe0-d827c131705e
¦   +-- aea97fc2-1856-4b51-a47e-c12e35ac7c47.vhd
¦   +-- f2aa92af-6f72-4af9-baab-4b1cc10f11af.vhd
¦   +-- filelog.txt
+-- fd9e028f-980c-d33b-7247-c71c4709d893
¦   +-- 02009757-f4a3-4f2a-84f1-e45adbecd9df.vhd
¦   +-- 048e5375-50ae-478b-b1e2-e950df272ee4.vhd
¦   +-- d3da9d9a-c664-46cd-bc8b-25a265bf1bf8.vhd
¦   +-- e4fb5af6-a172-4700-beff-bc8da16dc2d0.vhd
¦   +-- filelog.txt
+-- .snapshot
    +-- SC-daily_20121212121227
        ¦   +-- filelog.txt
            +-- 6cd5a5e4-f043-464f-9f28-e24f1f8bebe4.vhd
            +-- 7399c394-faf8-4a8a-b8fa-9b47fc60b8fc.vhd
            +-- 767720fe-9d7b-4178-8344-4c5bf6fbc895.vhd
            +-- b2ca4229-d599-4acc-a61b-d9bb9beb87f9.vhd
            +-- filelog.txt
6 directories, 20 files
W2K8 Metadata:
02009757-f4a3-4f2a-84f1-e45adbecd9df;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
b2ca4229-d599-4acc-a61b-d9bb9beb87f9;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
7399c394-faf8-4a8a-b8fa-9b47fc60b8fc;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
CentOS Metadata:
e4fb5af6-a172-4700-beff-bc8da16dc2d0;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
767720fe-9d7b-4178-8344-4c5bf6fbc895;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
6cd5a5e4-f043-464f-9f28-e24f1f8bebe4;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
Restore LOG:
[Wed Dec 12 11:56:41 2012] INFO: Logfile timestamp: 20121212115641
[Wed Dec 12 11:56:41 2012] DEBUG: GMT - Wed Dec 12 10:56:41 2012
[Wed Dec 12 11:56:41 2012] DEBUG: Version: NetApp Snap Creator Framework 3.6.0
[Wed Dec 12 11:56:41 2012] DEBUG: Profile: vCenter
[Wed Dec 12 11:56:41 2012] DEBUG: Config Type: STANDARD
[Wed Dec 12 11:56:41 2012] DEBUG: Action: restore
[Wed Dec 12 11:56:41 2012] DEBUG: Application Plugin: xen
[Wed Dec 12 11:56:41 2012] DEBUG: File System Plugin: null
[Wed Dec 12 11:56:41 2012] DEBUG: Policy: daily
[Wed Dec 12 11:56:41 2012] DEBUG: Snapshot Name: SC-daily_20121212110920
[Wed Dec 12 11:56:41 2012] INFO: Plugin validation for xen completed successfully
########## Parsing Environment Parameters ##########
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing VOLUMES - controller: 10.8.15.230 volume: vol_xenserver_00
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing NTAP_USERS - controller: 10.8.15.230 user: root
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing NTAP_SNAPSHOT_RETENTIONS - policy: daily retention: 3
########## Restore handling for plugin xen ##########
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Performing restore operation in xen plug-in
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating executor for the filer  10.8.15.230
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] DEBUG: Parsing NTAP_USERS - filer: 10.8.15.230 user: root
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating XEN RPC session on host : 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Getting the host instance and record information from host 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Found host with address 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Collecting host record information 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Host discovery completed successfully. Host address 10.8.15.206 with label xenserver-ipmeuedr
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating metadata file D:\XenServer_meta\xenserver-ipmeuedr_W2K8R2_SC-daily_20121212110920.metadata
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Reading the metadataFile D:\XenServer_meta\xenserver-ipmeuedr_W2K8R2_SC-daily_20121212110920.metadata
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating snapshot
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Checking VDI 8a530fff-0047-ddde-ebe0-d827c131705e/aea97fc2-1856-4b51-a47e-c12e35ac7c47 in snapshot 172.16.50.230:/vol/vol_xenserver_00/SC-daily_20121212110920
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00031] Not a valid snapshot. Not able to find aea97fc2-1856-4b51-a47e-c12e35ac7c47.vhd in snapshot SC-daily_20121212110920
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00032] Metadata file and snaphost information is not matching. W2K8R2
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restoring the VMs failed :10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restore operation failed for the host 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [scf-00006] Restore handling of plugin xen failed with exit code 1, Exiting!
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 11:56:44 2012] DEBUG: Application specific restore_cleanup operations are not yet implemented for plugin xen
[Wed Dec 12 11:56:44 2012] DEBUG: Exiting with error code - 1
Nachricht wurde geändert durch: Markus Kraus  Add debug log from snapshot
Nachricht wurde geändert durch: Markus Kraus Add metadata File
Nachricht wurde geändert durch: Markus Kraus add Restore Log
10 REPLIES 10
