FlexPod Discussions
expresspod, fas2240a, C220, how to delay boot on servers
infonet
Hello,
it is probably questions for Cisco forum but I rarely go there. I have customer where they often lose power, ups drains out and after power is back, things are turned on. Netapp boots later then C220 so you know problem.
Is there a way on UCS to delay boot of OS or hypervisor for certain number of minutes in order to wait for FAS2240 to boot up?
Thanks,
Damir
1 ACCEPTED SOLUTION
rarvind
Hello Damir,
You will be able to configure a Power Restore Policy using the Cisco Integrated Management Controller.
Browse to the below URL and please look for "Configuring the Power Restore Policy" -
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/gui/config/guide/2-0/b_Cisco_UCS_C-series_GUI_Configuration_Guide_201/b_Cisco_UCS_C-se...
You can induce a delay of upto 240 seconds before the sever is powered on.
Thanks
Arvind.
1 REPLY 1
rarvind
Hello Damir,
Thanks
Arvind.
