ONTAP Discussions
Connect-NcController using current context
JBRUNS2012
Using the dataontap 4.4 powershell toolkit to try to connect to a cDOT cluster/vserver and I have it working but one question.
Is there no way to tell the command to use the currently logged on user token?  Do I have to prompt for the users credentials even though they are right there in the windows address space to use?
When I use the connect-nacontroller, I only need to supply the -name parameter and it uses the currently logged on user.
11 REPLIES 11
