ONTAP Discussions
Disk used capacity and WAFL reserve and Snap reserve on Data ONTAP cluster
MOHAN1985
Hi,
I am trying to find command that can be run on DATA ONTAP cluster mode to get the below details,
(a) Used capacity of a disk
  Command used now : storage disk show
   This does not give the used capacity information.
(b) Is there a command that fetches WAFL reserve and Snap reserve details on cluster mode?
   7-mode command (aggr show_space) doesn't work on cluster mode.
Thanks,
Mohan
5 REPLIES 5
HARI_KRISHNA981
Hi mohan,
which version of data ontap c-mode you are using ???
Regards,
Hari
MOHAN1985
Hi Hari,
I use NetApp Release 8.2 Cluster-Mode.
Thanks,
Mohan
HARI_KRISHNA981
Hi mohan,
Please refer to the Link
https://library.netapp.com/ecm/ecm_download_file/ECMP1196780.
It contains clustered command map for the 7 mode administrators.
Let me know if need further info
Cheers,
Hari
Jervin
I am also facing the same issue in my 8.2 array. Please let me know if there is a solution to this issue
cluster1::> system node run -node * aggr show_space
2 entries were acted on.
Node: cluster1-01
aggr: no such command "show_space"
for more information type "aggr help".
Node: cluster1-02
jonm
try just netapp-cluster::> aggr show-space
