Subscribe
Highlighted
Does Edge work with OnCommand Unified Manager?
[ Edited ]
I finally managed to get Data ONTAP Edge installed and up and running, however, I was hopping to use it as part of an OnCommand Unified Manager demo.  OnCommand does "see" it via SNMP, however, when I try and give it the 'root' credentials, it complains with "Unable to validate host credentials.  Please make sure that provided login credentials and admin port/transport detail are valid."  When I click on "More Details" it just states "Internal error. (Error 13114).  I've added a few other filers to the OnCommand server and I don't recall having any issues doing so, so I'm wondering if there is something in Edge that is keeping it from working.  OnComamnd System Manager is able to log into the server so the API port seems to be working.  Any ideas will be greatly appreciated.
Re: Does Edge work with OnCommand Unified Manager?
Support for OnCommand Unified Manager is in our Road Map and is undergoing test. It is not supported at the moment.
Just to confirm does "is not supported" mean "will not work"?  Or, just "hasn't been fully tested"?  Put another way, does it surprise you I am having the problem I am having?  The point is, I don't care if it is supported, I just need it to work for a demo.  Not a demo of Edge, but of OnCommand.  Thanks!
Keith,
What version of OCUM are you testing with?
According to "dfm version" it is 5.0.2
Thanks.
Even with 5.1 (latest shipping), the release notes say:
    Data ONTAP Edge is not supported.
Sorry... I don't know. Hana might have a clearer answer. What DOT version is your VM?
Ug, I shut it down.  It was the 8.1.2_v-T.ova one.  I can boot it back up if you need the specific version it reports.  Thanks for your help...
No need. That tells me it was 8.1.2.
