Subscribe
Highlighted
Accepted Solution
FAS2020 huge CPU load with NFS v4
Hello, I hope I am asking this in the right area. I have a FAS2020 single controller, 12 300GB 15k SAS, NICs aggregated in a vif, a bunch of servers and 2 stations all running linux, everything GB LAN, connected to a SG300-28 Cisco switch.
Now problem is I am trying to make use of NFS namely vs4 and I get always 95-100% CPU load during transfers, and it's dramatic on files over 5GB. My client machines (a CentOS 6.4 and a openSUSE 12.3 used for testing) get kind of stuck and they freeze in the process. With NFS v3 it's around 60-70% but this is a no no, the speed is halved. As my filer has a single core, no M option for me, and I really think this is a load pure and simple. But NFS shouldn't exercise this on a filer with a single file copied over from a single station.
It has been recently wiped clean, installed Ontap 7.3.7, configured - and now I am just testing to see why is this happening before moving a few KVM machines on the filer. So nothing else is hammering the filer. Tried many NFS options; stopped for now at:
fstab on the client
192.168.1.200:/vol/vol_1/mnt/nfs/StupidNFSnfs4rw,bg,hard,rsize=65536,wsize=65536,timeo=60,actimeo=1,intr,sync,tcp 0 0
options nfs
nfs.acache.persistence.enabled on
nfs.always.deny.truncate on
nfs.assist.queue.limit   40
nfs.export.allow_provisional_access on
nfs.export.auto-update   on
nfs.export.exportfs_comment_on_delete on
nfs.export.harvest.timeout   1800
nfs.export.neg.timeout   3600
nfs.export.pos.timeout   36000
nfs.export.resolve.timeout   6
nfs.hide_snapshot        off
nfs.ifc.rcv.high         66340
nfs.ifc.rcv.low          33170
nfs.ifc.xmt.high         16
nfs.ifc.xmt.low          8
nfs.ipv6.enable          off
nfs.kerberos.enable      off
nfs.locking.check_domain on
nfs.max_num_aux_groups   32
nfs.mount_rootonly       on
nfs.mountd.trace         off
nfs.netgroup.strict      off
nfs.notify.carryover     on
nfs.ntacl_display_permissive_perms off
nfs.per_client_stats.enable  off
nfs.require_valid_mapped_uid off
nfs.response.trace       off
nfs.response.trigger     60
nfs.rpcsec.ctx.high      0
nfs.rpcsec.ctx.idle      360
nfs.tcp.enable           on
nfs.thin_prov.ejuke      off
nfs.udp.enable           on
nfs.udp.xfersize         32768
nfs.v2.df_2gb_lim        off
nfs.v2.enable            on
nfs.v3.enable            on
nfs.v4.acl.enable        on
nfs.v4.enable            on
nfs.v4.id.domain
nfs.v4.read_delegation   on
nfs.v4.write_delegation  on
nfs.webnfs.enable        off
nfs.webnfs.rootdir       XXX
nfs.webnfs.rootdir.set   off
df -h
Filesystem           total   used  avail capacity  Mounted on
/vol/vol0/          9216MB 1109MB 8106MB  12%  /vol/vol0/
/vol/vol0/.snapshot 1024MB   73MB  950MB   7%  /vol/vol0/.snapshot
/vol/vol_1/          921GB  623MB  920GB   0%  /vol/vol_1/
/vol/vol_1/.snapshot  102GB 8222MB   94GB   8%  /vol/vol_1/.snapshot
/vol/vol_2/          693GB  622MB  692GB   0%  /vol/vol_2/
/vol/vol_2/.snapshot   77GB 8284MB   68GB  11%  /vol/vol_2/.snapshot
sysconfig -r
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active, pool0)
    RAID group /aggr0/plex0/rg0 (normal)
      RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity     0c.00.0     0c    0   0   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      parity      0c.00.1     0c    0   1   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.2     0c    0   2   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.3     0c    0   3   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.4     0c    0   4   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.5     0c    0   5   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.6     0c    0   6   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.7     0c    0   7   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.8     0c    0   8   SA:B   0  SAS  15000 272000/557056000  274845/562884296
      data        0c.00.9     0c    0   9   SA:B   0  SAS  15000 272000/557056000  274845/562884296
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare       0c.00.10    0c    0   10  SA:B   0  SAS  15000 272000/557056000  274845/562884296 (not zeroed)
spare       0c.00.11    0c    0   11  SA:B   0  SAS  15000 272000/557056000  274845/562884296
aggr status -v
Aggr State       Status        Options
aggr0 online      raid_dp, aggr root, diskroot, nosnap=off,
raidtype=raid_dp, raidsize=16,
ignore_inconsistent=off,
snapmirrored=off,
resyncsnaptime=60,
fs_size_fixed=off,
snapshot_autodelete=on,
lost_write_protect=on
Volumes: vol0, vol_1, vol_2
Plex /aggr0/plex0: online, normal, active
RAID group /aggr0/plex0/rg0: normal
nfsstat (really don't know how to read this one, any hints there?) is attached. See also the 2 files attached for the load. Systems manager roughs this at 100% CPU load, wich is not ok.
The hardware seems fine - no warning anywhere, all tests passed. I configured NFS, cifs, ssh... I don't use the filer for anything else, just for testing these days.
What could cause this and what can I do about it? Please tell me what other relevant info should I post to nail this down.
Thank you.
Re: FAS2020 huge CPU load with nfsv4
I think this is the normal max write throughput for this platform with IP protocols.  FC can get you a bit higher, maybe 90MB/s sequential writes.  For sequential reads with IP protocols you get 2x the write throughputs, for FC a little more than 2x.  This platform is showing its age, and with 1 x 32-bit CPU and 1 GB of RAM just isn't very powerful.
It is an older device, yes. But I am pretty sure this is not the case: it's the not the speed over LAN and not the writes wich are fine, but the CPU load and the throttling of the clients during a simple copy of one bigger file, that gives me the headaches. A friend of mine has the same FAS (but with 7200 sata drives... a slower one) and no problems. I keep suspecting this can be delt with.
BTW here is a exportfs:
/vol/vol_1      -sec=sys,rw,root=192.168.1.50,anon=65535,nosuid
/vol/vol_2      -sec=sys,rw,root=192.168.1.50,anon=65535,nosuid
With NFSv3 I get around 25-30MB/s and slower CPU load (mount reads: nfs (rw,relatime,sync,vers=3,rsize=65536,wsize=65536,namlen=255,acregmin=1,acregmax=1,acdirmin=1,acdirmax=1,hard,proto=tcp,timeo=60,retrans=2,sec=sys,mountaddr=192.168.1.200,mountvers=3,mountport=4046,mountproto=tcp,local_lock=none,addr=192.168.1.200)):
> sysstat 1
CPU    NFS   CIFS   HTTP      Net kB/s     Disk kB/s      Tape kB/s    Cache
                               in   out     read  write    read write     age
56%    715      0      0   24682   676      524  31744       0     0       4s
49%    820      0      0   28237   775      236  39680       0     0       3s
44%    806      0      0   27775   760      259   8682       0     0       4s
57%    743      0      0   25632   703      383  52339       0     0       4s
45%    856      0      0   29511   807      620  24968       0     0       4s
56%    710      0      0   24490   670      288  34494       0     0       4s
What is wrong with NFSv4 where I get at least double the speed, but also the load, plus the client problems (mount reads: nfs4 (rw,relatime,vers=4.0,rsize=65536,wsize=65536,namlen=255,acregmin=1,acregmax=1,acdirmin=1,acdirmax=1,hard,proto=tcp,port=0,timeo=60,retrans=2,sec=sys,clientaddr=192.168.1.50,local_lock=none,addr=192.168.1.200)) ?
> sysstat 1
  1%     15      0      0       2     2      800    400       0     0       2s
  0%     14      0      0       2     1        0      0       0     0       2s
74%   2987      0      0   68615  1689       68   1285       0     0       2s
97%   2697      0      0   61904  1526     2002  76771       0     0     >60
97%   2361      0      0   54236  1338     1112  73964       0     0     >60
98%   2457      0      0   56519  1393      308  67556       0     0       2s
98%   2491      0      0   57144  1410     1271  67860       0     0       2s
98%   2451      0      0   56369  1390     1220  69872       0     0       2s
98%   2358      0      0   54167  1336     1028  76088       0     0       2s
98%   2576      0      0   59152  1458     1125  67430       0     0       2s
Thank you for your time madden!
PS: zeroed the spares and reallocated everything, the volumes and the aggregate - was a small problem with the aggr0.
nfs stat -d
Server rpc:
TCP:
calls       badcalls    nullrecv    badlen      xdrcall
129782      0           0           0           0
UDP:
0           0           0           0           0
IPv4:
129782      0           0           0           0
IPv6:
0           0           0           0           0
Server nfs:
calls       badcalls
129782      0
Server nfs V2: (0 calls)
null       getattr    setattr    root       lookup     readlink   read
0 0%       0 0%       0 0%       0 0%       0 0%       0 0%       0 0%
wrcache    write      create     remove     rename     link       symlink
mkdir      rmdir      readdir    statfs
0 0%       0 0%       0 0%       0 0%
Read request stats (version 2)
0-511      512-1023   1K-2047    2K-4095    4K-8191    8K-16383   16K-32767  32K-65535  64K-131071 > 131071
0          0          0          0          0          0          0          0          0          0
Write request stats (version 2)
0          0          0          0          0          0          0          0          0          0
Server nfs V3: (0 calls)
null       getattr    setattr    lookup     access     readlink   read
write      create     mkdir      symlink    mknod      remove     rmdir
rename     link       readdir    readdir+   fsstat     fsinfo     pathconf
commit
0 0%
Read request stats (version 3)
0          0          0          0          0          0          0          0          0          0
Write request stats (version 3)
0          0          0          0          0          0          0          0          0          0
Server nfs V4: (129782 calls, 388016 ops)
null           compound       badproc2       access         close          commit
0              129782         0 0%           23 0%          1 0%           0 0%
create         delegpurge     delegret       getattr        getfh          link
0 0%           0 0%           0 0%           129283 33%     5 0%           0 0%
lock           lockt          locku          lookup         lookupp        nverify
0 0%           0 0%           0 0%           8 0%           0 0%           0 0%
open           openattr       open_confirm   open_downgrade putfh          putpubfh
1 0%           0 0%           0 0%           0 0%           129130 33%     0 0%
putrootfh      read           readdir        readlink       remove         rename
162 0%         0 0%           3 0%           0 0%           1 0%           0 0%
renew          restorefh      savefh         secinfo        setattr        setclntid
329 0%         0 0%           0 0%           0 0%           2 0%           161 0%
setclntid_cfm  verify         write          rlsowner
161 0%         0 0%           128746 33%     0 0%
Read request stats (version 4)
0          0          0          0          0          0          0          0          0          0
Write request stats (version 4)
0          0          0          1          0          2          1          6          128736     0
Misaligned Read request stats
BIN-0    BIN-1    BIN-2    BIN-3    BIN-4    BIN-5    BIN-6    BIN-7
0        0        0        0        0        0        0        0
Misaligned Write request stats
128745   0        0        0        0        0        0        0
NFS V2 non-blocking request statistics:
0 0%       0 0%       0 0%       0 0%
NFS V3 non-blocking request statistics:
NFS reply cache statistics:
TCP:
InProg hits     Misses          Cache hits      False hits
0               129073          0               0
UDP:
In progress     Misses          Cache hits      False hits
0               0               0               0
nfs reply cache size=89600, hash size=1553
flows alloc'd=46, max flows=896
flows used=2, flows free=44
reserve entries=22, nflow LRU=0, grow LRU=0, opinfo releases=0
entry alloc fail=0, reply alloc fail=0, flow alloc fail=0, connection drops=0
Connection drops because of in progress hits:
        v3 conn dropped=0
        v4 conn dropped, no reconnect=0
num msg=0, too many mbufs=0, rpcErr=0, svrErr=0
no msg queued=0, no msg re-queued(xfc)=0
no msg unqueued=0, no msg discarded=0
no msg dropped=0, no msg unallocated=0
no msg dropped from vol offline=0, no deferred msg processed=0
sbfull queued=0, sbfull unqueued=0, sbfull discarded=0
no mbuf queued=0, no mbuf dropped=0
no mbuf unqueued=0, no mbuf discarded=0
(cumulative) active=0/143 req mbufs=0
tcp no msg dropped=0, no msg unallocated=0
tcp no resets after nfs off=0
tcp input flowcontrol receive=67542, xmit=0
tcp input flowcontrol out, receive=67542, xmit=0
Errors in the blocking export access check = 0
No of RAID errors propagated by WAFL = 0
sockets zapped nfs=0, tcp=0
reply cache entry updated on socket close=0
no delegation=0, read delegation=0, write delegation=0
v4 acls set=0
nfs msgs counts: tot=143, free=64, used=0, VM cb heard=0, VM cb done=0
nfs msgs counts: on assist queue=0, max on assist queue = 1, cut off for assist queue=57
nfs msgs counts: waiting for access resolution=0, cut off for access resolution=57
v4 reply cache opinfo: tot=89957, unallocated=89701, free=56, normal=0, rcache=200
v4 reply cache complex msgs: tot=33733, unallocated=33605, free=28, normal=0, rcache=100
v4 wafl request msgs: tot=133, unallocated=69, free=64, used=0
v1 mount (requested, granted, denied, resolving) = (0, 0, 0, 0)
v1 mount (frozen vol pending, frozen vol exceeded) = (0, 0)
v1 unmount (requested, granted, denied) = (0, 0, 0)
v1 unmount all (requested, granted, denied) = (0, 0, 0)
v2 mount (requested, granted, denied, resolving) = (0, 0, 0, 0)
v2 mount (frozen vol pending, frozen vol exceeded) = (0, 0)
v2 unmount (requested, granted, denied) = (0, 0, 0)
v2 unmount all (requested, granted, denied) = (0, 0, 0)
v3 mount (requested, granted, denied, resolving) = (0, 0, 0, 0)
v3 mount (frozen vol pending, frozen vol exceeded) = (0, 0)
v3 unmount (requested, granted, denied) = (0, 0, 0)
v3 unmount all (requested, granted, denied) = (0, 0, 0)
admin requested rmtab entry flushes = 0
mount service requests (curr, total, max, redriven) = (0, 0, 0, 0)
access cache lookup requests (curr, total, max) = (0, 20, 1)
access cache (hits, partial misses, misses) = (132095, 0, 1)
access cache nodes(found, created) = (132095, 1)
access cache requests (queued, unqueued) = (0, 0)
access cache requests unqueued by (flush, restore) = (0, 0)
access cache read requests (queued, unqueued) = (0, 0)
access cache write requests (queued, unqueued) = (0, 0)
access cache root requests (queued, unqueued) = (0, 0)
access cache expired hits (total, read, write, root) = (0, 0, 0, 0)
access cache inserts (full, partial, dup, subnet, restore) = (0, 0, 0, 0, 1)
access cache refreshes requested (total, read, write, root) = (0, 0, 0, 0)
access cache attribute resolutions requested but not scheduled because we are over the threshold(total, read, write, root) = (0, 0, 0, 0)
access cache refreshes done (total, read, write, root) = (0, 0, 0, 0)
access cache errors (query, insert, no mem) = (0, 0, 0)
access cache nodes (flushed, harvested, harvests failed) = (0, 0, 0)
access cache nodes (allocated, free) = (2000, 1998)
access cache qctx (allocated, free) = (500, 500)
access cache persistence errors (total) = (0)
access cache persistence nodes handled (restored, saved) = (1, 4)
access cache persistence rules deleted (total) = (1)
access cache persistence rules with mismatched schema (total) = (0)
access cache persistence memchunks (allocated, freed) = (6, 6)
assist queue (queued, split mbufs, drop for EAGAIN) = (0, 11144, 0)
NFS re-drive queue(curr, max, total) = (0, 0, 0)
Direct NFS re-drive(memory, webNFS) = (0, 0)
RPCSEC_GSS context limit=0
current context count=0, maximum context count=0
context reclaim callbacks=0, context idle/expired scans=0
vm pressure callbacks=0
contexts created=0, contexts deleted=0
contexts deleted due to vm pressure=0
contexts deleted due to context limit=0
contexts deleted due to idle/expiration=0
requests exceeding timeout=0
Files Causing Misaligned IO's
Later edit by: Horia Negura
Re: FAS2020 huge CPU load with NFS v4
Started everything again from scratch. Same issue, but the jumbo frames (mtu 9000 on the filer, switch, and the CentOS client) and the priority setting helped about 10% with the CPU load problem. Now, how can I get rid of the missaligned requests, is this normal with a nfs setup? The reallocate command doesn't help. I keep getting them, they keep increasing, it is obvious as I did some nfsstat -z:
1        0        0        0        0        0        0        0
349274   0        0        0        0        0        0        0
What I did:
-reinitialised with option 4a (created a 3 disk aggr with 1 vol0 for root);
-upgraded the OS due to missing files (7.3.7); the following were done via Systems Manager;
-added 7 disks all at once to the aggr;
-resized to minimum the default root vol0 to 20 GB as per best practices;
-created 2 flex volumes in the aggr;
-resized them a bit to fit my needs and disabled thin provisioning on those 2;
-free space for the aggr left around 10%;
-tested again.
Is there something wrong with this approach?
The misaligned stats show a count of 4KB (or some increment of 4KB) IOs and the offset they had into a WAFL block.  In your case all IOs are arriving in BIN-0 which means they are aligned.  If BIN-1-7 were incrementing then you have unaligned IO.  I think the write performance you observe is normal for this platform.  When you do the big file copy from the syssstat v4 earlier you are reaching CPU bottleneck, and with v3 you were reaching some other bottleneck.  Perhaps the use of the sync mount option in your v3 trial caused IOs to be issued serially and was throttling work requested of the filer.  In the v4 example though CPU resources are exhausted so any request is going to have to queue CPU which drives up response times. Using jumbo frames helped reduce CPU (more data, less metadata, per frame)  which enables more CPU for other work.  I can't think of anything else you can enable that will reduce CPU.  As I mentioned earlier, the v4 write throughput you observed is about what can be expected from this platform.  Disk type doesn't matter for this workload because you are hitting CPU bottleneck.  I also mentioned you could get a little more write throughput using FCP.  The reason is that with Ethernet protocols the CPU is used for building Ethernet frames and IP packets compared with FCP where the equivalent work is being done in hardware on the fibre channel adapter itself.
I really don't think you're missing something.  The only suggestion I have is to open a support case and provide them a perfstat for analysis.
Good luck!
Chris
Thank you for clearing this up - was becoming obsessed with those horror stories about misaligns ! I also misunderstood you answer regarding FCP, thought you were refering solely to the bandwidth gains and forgot about the extrawork that TCP/IP throws to the CPU.
This is it then, I will try to overcome my NFS4 fears.
PS Do you know exactly what CPU is? Wich Mobile Celeron? Is there any way to find out more about the hardware, RAM also, than sysconfig -a?
Hi,
If you prefer nfs v3 I think you should be able to get similar performance as v4 with the right mount options.  Maybe check the Oracle on NetApp best practices tech report for some Linux + NFS optimization tips: http://www.netapp.com/us/media/tr-3633.pdf
Regarding CPUs and memory I don't think more information is available in a Data ONTAP command output.  Maybe if you boot into diags (the one from control-c at boot) there is an option to show more details about components.
Cheers,
Chris
