Subscribe
Highlighted
Is it possible to Snapvault from a volume in 32-bit aggregate to a volume in a 64-bit aggregate?
HI
I just want know whether is it possible to do Snapvault transferring from  a volume in a 32-bit aggregate to a volume in 64-bit aggregate?
Thanks
Re: Is it possible to Snapvault from a volume in 32-bit aggregate to a volume in a 64-bit aggregate?
7-mode or C-mode? In 7-mode SnapVault is using logical replication, so it should be possible.
HI Aborzenkov,
It is within two 7-Mode systems.
Thanks
SnapVault between 32-bit and 64-bit aggregates is possible and supported.
Volume SnapMirror between 32-bit and 64-bit is possible with 8.1 and higher.
Best Regards
Michael
