ONTAP Discussions
Modify management network interface on cluster mode with 2 nodes
REDOUANELIANI
Hi,
I want to modify my network management config and may you advise me what is the best solution to do it
We have a FAS3250 with two node on cluster mode.
I'll expect to modify 6 interfaces :
Two by node (e0m and SP(RLM) and the cluster management (e0a) ?
Firstly,i think the best solution is to connect by the SP(RLM) for each node and modify e0m interface and the cluster management ?
and finally connect by cluster management to modify the SP ?
What do you think ?
Is this command good to modify management interface and e0m ?
network interface modify -vserver "name" -lif
"datalif1" -address "IP" -netmask "mask" -auto-revert
true
What is the command to modify the SP(RLM) ?
Thanks for your reply
0 REPLIES 0
