ONTAP Discussions
Need help !!! unable to modify or delete LIF on node of a cluster
SANIDHYA1986
Hi ,
I am using Netapp cluster mode 8.2 simulator on VMware fusion.
I have set 2 node cluster. The network configurations are fine on one node but the second node is not reachable from the cluster.
clus1::network routing-groups route> network interface show
            Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
clus1
            cluster_mgmt up/up    192.168.226.10/24  clus1-01      e0c     true
clus1-01
            data_int1    up/up    192.168.199.10/24  clus1-01      e0a     true
            data_int2    up/up    192.168.199.11/24  clus1-01      e0b     true
            mgmt1        up/up    192.168.226.20/24  clus1-01      e0c     true
clus1-02
            clus1        up/-     169.254.246.5/16   clus1-02      e0a     true
            clus2        up/-     169.254.51.137/16  clus1-02      e0b     true
            mgmt1        up/-     192.168.226.11/24  clus1-02      e0c     true
The IP subnet 169.254.0.0/16 does not exist in my system anywhere, so I wanted to change it to 192.168.199.0/24 but it was throing error :
clus1::network interface> modify -vserver clus1-02 -lif clus1 -home-node clus1-02 -home-port e0a -address 192.168.199.20
Error: command failed: Cluster configuration data can only be changed on node where cluster lif resides.
When i tried to delete the LIF then it showed following error :
clus1::network interface> delete -vserver clus1-02 -lif clus1
Error: command failed: Removing cluster lifs that are part of the sitelist is not permitted
Routing groups are :
clus1::network routing-groups> show
          Routing
Vserver   Group     Subnet          Role         Metric
clus1
          c192.168.226.0/24
                    192.168.226.0/24
                                    cluster-mgmt      20
clus1-01
          c192.168.199.0/24
                    192.168.199.0/24
                                    cluster           30
          n192.168.226.0/24
                    192.168.226.0/24
                                    node-mgmt         10
clus1-02
          c169.254.0.0/16
                    169.254.0.0/16  cluster           30
          c192.168.0.0/16
                    192.168.0.0/16  cluster           30
          n192.168.226.0/24
                    192.168.226.0/24
                                    node-mgmt         10
Thanks in advance
2 REPLIES 2
dennisvisser
It looks like the first sim is created without a cluster switch.
The second looks dead. No up interfaces at all. To completely verify it try 'network port show'.
The error messages is made by design:
The RDB (replication database) keeps track of what and where the cluster interfaces are. --> Proof of this you can find in 'cluster ping-cluster -use-sitelist true' ...
if you want a working clustered simulator my advise is (unfortenately ... start over again)
download 8.2 simulator
Start installation of node 1 create cluster --> choose for a clusterswitch
Start installation of node 2 join cluster
If you want only 1 cluster port for the simulator (never in production!!)
change one of the home port of the cluster to the homeport of the other interface. (e.g. two times e0d)
revert the lif to its home port
change the role of the port to whatever you need.(intercluster, data ...)
SANIDHYA1986
Thanks
I have created a new cluster and its working fine now.
