I recently did a head swap between a FAS2050 and a FAS3210 without too much of a problem. I used the root volume from the FAS2050 and everything came up fine with the exception of the iSCSI configuration. All of the LUN's came up, but none of the mappings came up and I had to re-create it manually. This was not a huge deal for this swap since it had a total of two connections, but the next two I do have somewhere in the area of about 20 mappings each.
Is there any way I can avoid having to re-do this all manually or did I miss something with the iSCSI setup when I did my first migration so that the information didn't copy over? The same network address is being used, so I'm hoping that most of the initiators can just pick up on the setup.
Thanks.
