ONTAP Discussions
SMSQL clone/restore from vault c-mode filers
pcmssysadmin
Hi I am new to c-mode and have just set up our first in guest iscsi luns. The volumes are vaulted to the same SVM as the primarary volumes and then the vaults are mirrored to another SVM at a different site.
When trying to do a clone or restore from a vault snap the SMSQL wizard is trying to mount the clone from the offsite SVM not the local one. I have just checked through the SMSQL docs and this says to use a seperate SVM for the vault volumes is this the only way to restore/clone from the onsite vault or should the SMSQL wizard be able to see and work with the local vault snaps on the current SVM.
0 REPLIES 0
