ONTAP Discussions
Snapmirror replication problem after move (10Mbps WAN)... Status: Transfering but Progress: 0KB...
neves_jacques
Good Morning,
I had a fully running SnapMirror configuration on my Gigabit LAN last week.
We've just moved the target filer (fas02) to the DR site.
We have now a 10Mbps WAN connection between the two sites.
I've run a "snapmirror update volcifs" the status is "Transferring" but Progress stay forever "0KB".
Here is the output and the /etc/snapmirror.conf
slpfas02> snapmirror status -l volcifs
Snapmirror is on.
Source:                 connection:volcifs
Destination:            slpfas02:volcifs
Status:                 Transferring
Progress:               0 KB
State:                  Snapmirrored
Lag:                    99:20:08
Mirror Timestamp:       Fri Dec 23 08:32:02 CET 2011
Base Snapshot:          slpfas02(0101177175)_volcifs.118
Current Transfer Type:  Update
Current Transfer Error: -
Contents:               Replica
Last Transfer Type:     Update
Last Transfer Size:     278036 KB
Last Transfer Duration: 00:00:16
Last Transfer From:     connection:volcifs
Here is below my configuration:
Source: fas01 (FAS3020)
Target: fas02 (FAS3020)
slpfas02> rdfile /etc/snapmirror.conf
connection=multi(192.168.150.41,192.168.150.42)(192.168.156.41,192.168.156.42)
connection:volcifs slpfas02:volcifs wsize=202375 - - - -
connection:volnfs slpfas02:volnfs wsize=202375 - - - -
connection:volnfslab slpfas02:volnfslab wsize=202375 - - - -
Thanks for the support.
Regards,
JNV
2 REPLIES 2
SNEWNAMBBT
Just to start - you've checked all the simple things right? You can ping between the filers, you've made sure DNS resolves the names correctly and/or the host file was updated with the correct IP addresses for each filer?
neves_jacques
Hi Sam,
Thanks for your reply. Yes, DNS is correctly defined.
I've just solved the problem.
I've modified the MTU size from 1500 to 1400 bytes on the interface now it's working fine again.
Best regards,
Jacques Neves
