ONTAP Discussions
cDOT 8.2 ifgrp and network interface
ANTON_MSSM
hi everyone I have a strange issue, not sure if its an issue but its strange.
running cdot 8.2 and having an issue with my network ports.
The network team tells me there is nothing wrong. but I see an interface that shows down, but also shows up, I am confused.
mshs6290-01> ifconfig e5a
e5a: flags=0x9f0c867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 02:a0:98:46:ee:xx (auto-1000t-fd-up) flowcontrol full
        trunked a0a
mshs6290-01> ifconfig e0a
e0a: flags=0xaf0c867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        trunked a0a
mshs6290-01> ifgrp status
default: transmit 'IP Load balancing', Ifgrp Type 'multi_mode', fail 'log'
a0a: 1 link, transmit 'none', Ifgrp Type 'single_mode' fail 'default'
         Ifgrp Status   Up      Addr_set
        up:
        e0a: state up, since 11Oct2013 15:18:50 (33+19:48:09)
                mediatype: auto-1000t-fd-up
                flags: enabled
                input packets 640706, input bytes 82109888
                output packets 1539297, output bytes 84429207
                output probe packets 486988, input probe packets 0
                strike count: 0 of 10
                up indications 1, broken indications 0
                drops (if) 0, drops (link) 0
                indication: up at 11Oct2013 15:18:50
                        consecutive 2922348, transitions 1
        down:
        e5a: state down, since 11Oct2013 15:18:50 (33+19:48:09) --  (how is this down ?)
                flags: enabled
                input packets 1100816, input bytes 110153608
                output packets 535693, output bytes 27808237
not sure what to do here, also fairly new to cdot and have a hard time trying to manipulate the interfaces
7 REPLIES 7
HARI_KRISHNA981
Hi Anton Lebedev,
Check with the netdiag command and find out whether particular interface is up or down exactly.
you can refer the below link for the command reference.
http://www.wafl.co.uk/netdiag/
Paste the output of netdiag if it shows the same problem.
Regards,
Hari.
ANTON_MSSM
Hari, i dont think netdiag is part of cdot commands, I dont see it listed in the manual; https://library.netapp.com/ecm/ecm_download_file/ECMP1196817
HARI_KRISHNA981
Oops, sorry! overlooked...
which series of filer you are using ?
Regards,
Hari
aborzenkov
Well, it is single mode so only one link is normally active. I do not have any single mode vifs to compare, unfortunately.
Отправлено с iPhone
14 нояб. 2013 г., в 19:15, "Anton Lebedev" <xdl-communities@communities.netapp.com<mailto:xdl-communities@communities.netapp.com>> написал(а):
<https://communities.netapp.com/index.jspa>
created by Anton Lebedev<https://communities.netapp.com/people/ANTON_MSSM> in Products & Solutions - View the full discussion<https://communities.netapp.com/message/120679#120679>
trunked a0a
trunked a0a
up:
flags: enabled
down:
flags: enabled
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/120679#120679>
Start a new discussion in Products & Solutions by email<mailto:discussions-community-products_and_solutions@communities.netapp.com> or at NetApp Community<https://communities.netapp.com/choose-container.jspa?contentType=1&containerType=14&container=2068>
ANTON_MSSM
can I change the ifgrp a0a or do I need to re-create it to change it from singlemode to multimode_lacp ?
aborzenkov
You cannot change ifgrp type and it requires changing of switch configuration and possibly re-cabling.
ShivRamagir
Hi,
How did you resolve this issue. we are facing same inssue for one of our customer. Your comments would be helpfull to us........
