NetApp Developer Session - Use Case: Access Performance Metrics on C-Mode Systems
by New Contributor on ‎2012-09-10 02:50 PM
This session is about querying performance counters of a cluster mode system. The used programming language is Java and the NetApp Manageability SDK provides a handy interface to bring both together.
The session showed how to connect to a cluster mode system and how to traverse the object->instance->counter hierarchy. In brief two queries were sent to the storage system to get all cpu_usage counters. As these counters are within the object category "system", one query was used to get all the instances. A second query was used to specify object category and the instances returned in the prior query.
Atypically the values weren't sent to a database. Instead they were enqueued in a messaging middleware to transport/distribute them.
The code can be found at . It comes as an eclipse project which can be imported to run quickly.
Get your development environment ready and watch the recording of the session here:
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
