StorageGRID API Reference for StorageGRID 8.5
by povey Netapp Alumni on ‎2012-07-15 11:13 AM
The HTTP API Reference provides a detailed description of the HTTP API used by thirdparty applications to access the NetApp® Stor­ageGRID® system and manage the objects stored in the StorageGRID system.
This guide is intended for technical managers who wish to gain a basic understanding of the StorageGRID API and for developers who are creating applications that interface with the StorageGRID system.
This document assumes familiarity with many terms related to computer operations and programming, network communications, and operating system file operations. There is wide use of acronyms.
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
