An Introduction to Software Licenses in clustered Data ONTAP 8.1.x.
by Frequent Contributor on ‎2012-10-25 01:40 PM - edited on ‎2014-09-26 11:46 AM by alissa Former NetApp Employee
Let’s say you purchase a 4 node clustered Data ONTAP system with CIFS.  To enable this cluster you get a Cluster Base license key with a 4 node count issued against a unique Cluster Serial Number (1-80-xxxxxx), and you get a 4 node CIFS license key that also contains the Cluster Serial Number (so it can’t be used in other clusters).  For add-on software purchases (e.g., add SnapMirror), you need to provide the Cluster Serial Number with your order and a new license key for 4 nodes of SnapMirror (or whatever feature you ordered) will be issued against that 1-80-xxxxxx serial number.
NOTE: If you try to add a permanent license key to a cluster with a different cluster serial number, ONTAP 8.1 will throw an error right away and will not allow it.
For evaluations, send a request to your NetApp representative and they will provide evaluation (temporary) license keys for whatever features you need.  The eval keys they provide last up to 1 year and work for up to 8 nodes. The keys have a fixed expiration date and can only be installed once (unlike ONTAP 8.1 7-mode where you can install a temp key up to 3 times for 90 days each time).
There are two types of evaluations: new cluster evals, and cluster feature evals within an existing cluster. For new cluster evals, CMET will provide a Cluster Base license key that enables a cluster of up to 8 nodes to be created (with no expiration date); CMET will also issue eval license keys for features (e.g., CIFS, FlexClone, etc.) that enable use for up to one (1) year for a cluster of up to 8 nodes.  If you have an existing cluster and want to evaluate a particular ONTAP feature, CMET will issue an eval license key that will enable the feature for up to one year within your existing cluster.
NOTE: V-Series evaluations are handled by the V-Series hardware, and do not use cluster evaluation license keys.  Please refer to V-Series documentation for further details.
Features that can be licensed for clustered Data ONTAP 8.1.x:
Feature                          Description
Base                              Base License w/cluster size limit (# of nodes)
Mirror                             Mirror License
CIFS                              CIFS License
SnapRestore                  SnapRestore License
FlexClone                      FlexClone License
NFS                              NFS License
SnapMirror_DP              SnapMirror Data Protection License
iSCSI                            iSCSI License
FCP                              FCP License
SnapManager_Suite       SnapManager Suite License
SPA                              SPA License
As per my attached excel sheet needs to verify what all licence are active and what are deactive.
Other than this as a best practice what are the licence which we should procure of better enhansmant.
or pls share the list of all license used by NetApp along with their advantage and disadvantages.
Sunil RAwat
Hi Sunil,
Thank you for your comment. Unfortunately, the excel sheet you are referring to did not make it into the comments.
This article was originally written for Data ONTAP 8.0 Cluster-Mode. With Clustered Data ONTAP 8.3 we have new commands to check the status of licenses on the cluster.
The command below can be used to check the status of licenses on the cluster
cluster1::> system license status show
The command below can be used to check the licenses are available on the cluster
cluster1::> system license show
To your question about licenses that are recommended for a cluster, the answer depends on the workloads that are rolled out on your cluster. Your local NetApp technical team can assist you in this matter.
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
