Estimate Storage Efficiency Space Savings Using Space Savings Estimation Tool v4.1 (SSET 4.1).
by smoulton Former NetApp Employee on ‎2012-08-28 10:46 AM - edited on ‎2017-01-25 09:57 AM by Frequent Contributor
Estimate Storage Efficiency Space Savings Using Space Savings Estimation Tool version 4.1 (SSET 4.1).
Introduction:
SSET (Space Savings Estimation Tool) 4.1 simulates the algorithms used by NetApp deduplication, data compression, zero-block elimination and data compaction to give an estimate on space savings of an existing data set. The data set may reside on any storage that is accessible via a CIFS or NFS mount point, or inside a local directory on the client system.
This tool is a confidential NetApp® product. It is intended only for use by NetApp employees, authorized NetApp partners, and NetApp customers.
Note: The tool is intended to be used for estimation purposes only
Features in SSET 4.1
Support for analysis of the following configurations:
  • Deduplication only savings estimate
  • Compression only savings estimate
  • Data Compaction only savings estimate
  • Combination of Deduplication, Compression and/or Data Compaction savings estimate
*Zero-block elimination savings estimate will be included in all the above configurations.
What's new in v4.1?
- 2TB scan limit removed. The tool can process up to 1024PB of data in a single run.
- Performance improvements to make the tool run faster!
OS Support: Windows and Linux
Tool Support: The SSET 4.1 is only supported via NetApp Communities. Create a new discussion or comment on this page or
send mail to ng-wafl-pm for any questions or support.
Download Link:
NetApp customers, authorized NetApp partners and NetApp employees can download the tool from ToolChest
- NetApp employees and authorized NetApp partners can also download the tool from  Field Portal
Comments
All,
I am trying to download the SSET tool but I can't seem to find it on this page. It is supposed to be in the document somewhere. Can you tell me where it is?
 I am too looking for a download link.
Link?
Yeah I just tried that link anf got this error: Error While Logging into the Field Portal You have experienced an error in the NetApp Single Sign-in login process. Would it not be better to just put this on the NOW site in the tools section?
Thanks
allison Former NetApp Employee
@michaeljay Unfortunately, if it is in the Field Portal, it's meant for NetApp Partner use and not general customer use. If you need to use this tool, please contact your account manager or selling partner.
Anybody else gets "Percentage of Duplicate Data: 100.00"  for A-SIS deduplication (-a)?
I get that regardless of data I use it on.
New Contributor
Hi,
On what Linux version should this work???
xxx@toaster4:~/sset$ ls -l
total 708
-rwxr-xr-x 1 xxx yyy 434877 Jun 25 2015 find_space -rwxr-xr-x 1 xxx yyy 284700 Jun 25 2015 SSET 3.1 Communities Readme.pdf
xxx@toaster4:~/sset$ ./find_space
-bash: ./find_space: No such file or directory
xxx@toaster4:~/sset$ uname -a
Linux toaster4.mydomain.tv 3.2.0-4-amd64 #1 SMP Debian 3.2.73-2+deb7u2
x86_64 GNU/Linux
xxx@toaster4:~/sset$ ldd find_space
                not a dynamic executable
xxx@toaster4:~/sset$ file find_space
find_space: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.2.5, not stripped
Please advice!?
-Arnout
Looks like I potentially found the answer here. Will keep you posted.
http://ubuntuforums.org/showthread.php?t=1607086
where is the download link?
Member
"Download the attached SSET31_Win_Linux.zip file"
Where is the download link for the attached file?
Occasional Contributor
I'm getting the error that Arnout got. How do you run this on 64 bit Linux when you can't install the 32 bit libraries? It's RH 6 and I can't modify the build I have.
Answering my own question. You can get it to run by doing the following:
# mkdir /usr/software
# ln -s /lib64 /usr/software/lib
Member
Hi Team,
IHAC who is running the SSET tool in his environment for MongoDB on Cent OS ( Vmware ESXi), the error message is as :
bash: ./find_space: /usr/software/lib/ld-linux-x86-64.so.2: bad ELF interpreter: No such file or directory
Kindly assist in resolution.
Rgds,
Gurdeep Singh.
Member
IHAC that is running into issues. Here is the feedback he is giving us. Need to get him a response quickly.
most recent reply:
I’m scanning a folder within the volume where the SSET tool resides, it is 1.6TB in size however there is plenty of free space, over 256GB worth. I have tried running the tool from the main C: drive and have attempted different combinations of the switches. I just noticed the output of the command showed the following - Usage Error: Could not recognize: ?p
This occurs no matter where I run the tool from? Thoughts
Previous question from customer:
We were attempting to run the tool to receive stats for Deduplication, compression and compaction combined savings by issuing the following command :  e:\tools\find_space -f work.fp –p e:\DATA
The tool would prompt us for the user agreement and when answering yes its next step just displayed the usage arguments. Below is the output from the tool :
C:\Users\admin>e:\Tools\find_space -f work.fp -p e:\DATA
Data ONTAP Space Savings Estimation Tool Version 4.1
This tool is a confidential NetApp product. By running it you
agree to keep it and the results confidential between you and
NetApp. Do you accept the agreement and want to continue (Y/N) [N]? y
find_space: Usage Error: Could not recognize: ?p
Program: find_space
Description: This program scans the entire path (as provided with -p
             option) and estimates the  space savings that  will be
             achieved by Compression (switch -c), A-SIS deduplication
             (switch -a), Data compaction (switch -o) or Compression
             followed by A-SIS deduplication (switches -c and -a).
Usage: find_space  -a | -c | -o | -ac
                   [-h Help]
                   -f <name of log file>
                   [-g <Compression group size>]
                   [-o Do additional data compaction]
                   -p <path to scan>
                   [-T <temp dir>]
                   [-s <summary file>]
                   [-t <num of reader threads>]
                   [-w <num of worker threads>]
                   [-q quiet mode]
C:\Users\admin
You need to specify the Deduplicaiton (-a), Compression (-c) and Compaction (-o) switch while running the command.
C:\Users\admin>e:\Tools\find_space –a –o –c –g 2 -f work.fp -p e:\DATA
The command options and example output are mentioned in the accompanying readme file.
New Contributor
Hello all!
I have an issue where a customer of mine is trying to run SSET against an NFS mounts ESX datastore from a linux machine. They are getting a "Could not allocate inode hash" message and then SSET quits.
Any advice on this?
Thanks!
From Customer:
[Host\user@machine:/vmfs/volumes] /tmp/find_space  -a -f /tmp/NetAppLogs/App_dedup.log -p J: -T /vmfs/volumes/qa_datastore0\ \(Fast\ Disk\)/NetAppTmp -s /tmp/NetAppLogs/App_dedupsummary.txt
NetApp.
Could not allocate inode hash.
Hello,
I've just tested the new 4.2 version of SSET based on Python on Windows, and I have several points I wanted to share:
- Python is very common on Linux, not on Windows. Introducint Python requirement on Windows is not a good idea IMHO. The good thing with "find_space.exe" is that you can just copy it over to a Windows server and run it locally for best performance
- I'm having several issues with Python version:
D:\Downloads\SSET4_2\sset4_2\sset4_2_windows>python sset.pyc -a -c -o -p "D:\$NTAP\OneDrive - NetApp Inc"
Data ONTAP Space Savings Estimation Tool Version 4.2
NetApp.
Do you accept the agreement and want to continue (Y/N) [N]?:y
Type of Workload[optional]:
Would you like SSET estimates sent via an E-mail (Y/N) [N]?: n
find_space: Usage Error: Could not recognize: -
sset.pyc: Fatal error while invoking find_space. Exiting...
D:\Downloads\SSET4_2\sset4_2\sset4_2_windows>find_space.exe -a -c -o -f sset.fpr -p "D:\$NTAP\OneDrive - NetApp Inc"
The Fingerprint file that you have specified already exists.
The tool will overwrite the file. Do you want to continue (Y/N) [N]? y
Scanning finished. Sorting the FP file.
NOTE: This report and the information are confidential.
Results are estimates only. Actual storage savings may
be different.
Scan duration in seconds: 144
Total Number of Directories: 574
Total Number of Files: 6562
Total Number of 4K Blocks: 2377525
Total Number of Zero-Filled Data Blocks: 2011
Thank you,
Kind regards,
Michel
Hello
I have executed the script , it creates the .fp file but i'm not able to open it for the following error
Any suggestions ? How can i open the file ?
Regards,
Alessio
Hello Alessio,
Did you install Python? If yes, is it added to the PATH environment variable?
If you're based in Luxembourg (I see LUX in your username), I would be glad to help.
Kind regards,
Michel
Hello Michel,
yes i am  Smiley Happy
nice to meet you
I have installed Phyton....and i have just created the environemt variable named PYTHONPATH with all the content of the Python folder.
Now am i able to read the fp file ? how ?
Thanks,
Alessio
Hello Alessio,
Nice to meet you too!
Instead of PYTHONPATH, try to rather set PATH variable like below:
Path=C:\Program Files\Python36\Scripts\;C:\Program Files\Python36\;C:\Program Files\...
Kind regards,
Michel
Michel,
I have added all the folder of Python directory to the existed PATH variable.
Now , how i can "read" the .fp file ?
Alessio
Hello Alessio,
The Python script does not work on my PC, apparently due to spaces or special characters in folders' names, so I can't help further.
Depending on the size of the subfolders, the Python script might run for a while, and should process the "fp" file automatically (it's my guess).
If you're struggling with Python version, I would recommend using "find_space.exe" on Windows, it works fine.
I've sent you a private message with my details.
Kind regards,
Michel
Hello
i run the script as follow
but it creat a summary file report (ntap.txt) empty. I have also a .fp file of 8 GB ( about 1 TB scanned )
How can i analize the summary ? Is it possible to "see" the fp file ? How ?
Thanks
Regards,
Alessio
Member
Hello all,
I found a bug with sset 4.2.
SSET is abort with error when it try to open an *empty* folder.
As find_space.exe works fine with empty folders, the bug seems in the wrapper.
Here is the result of sset and find_space.exe:
############### When sset met an empty (sub)folder, it stopped with error. ###############
D:\SSET>python sset.pyc -a -c -o -p D:\test
NetApp.
volume: abc completed
Traceback (most recent call last):
File "merge_sort.py", line 67, in <module>
main(sys.argv[1], sys.argv[2])
File "merge_sort.py", line 60, in main
assert len(split_files) == 1
AssertionError
Could not open the sorted fp file
Error 2
############### find_space.exe works fine with empty folder. ###############
D:\SSET>find_space.exe -a -c -o -f fp -s summary -p D:\test
The Summary file that you have specified already exists.
be different.
Scan duration in seconds: 0
Total Number of Directories: 4
Total Number of Files: 5
Total Number of 4K Blocks: 3313
Total Number of Zero-Filled Data Blocks: 0
Secondary Compression
Total Number of Blocks Saved by Compression: 17
Compression Savings Ratio: 1.01:1
Deduplication
Total Number of Blocks Saved by Deduplication: 5
Deduplication Savings Ratio: 1.00:1
Data Compaction
Total Number of Blocks Saved by Data Compaction: 2
Data Compaction Savings Ratio: 1.00:1
Overall Volume level Savings Ratio: 1.01:1
Hope this help.
Itaru
Hello
I met an error 6 on sset 4.2, any idea. The tests have been done with W2012/ W8 /W10
Best regards
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
