Hi Everyone,
I have a FAS2554 with 20x SATA and 4 x SSD. So, they're split between the two controllers.
My problem is that I am having a difficult time creating a Flash Pool, to leverage the SSDs.
fas2554-b> aggr status -v
Aggr State Status Options
aggr0 online raid_dp, aggr root, diskroot, nosnap=off, raidtype=raid_dp,
64-bit raidsize=12, ignore_inconsistent=off,
hybrid_enabled snapmirrored=off, resyncsnaptime=60,
fs_size_fixed=off, lost_write_protect=on,
ha_policy=cfo, hybrid_enabled=on,
percent_snapshot_space=0%,
free_space_realloc=off
Volumes: vol0
Plex /aggr0/plex0: online, normal, active
RAID group /aggr0/plex0/rg0: normal, block checksums
fas2554-b> aggr add aggr0 -T SSD 2
aggr add: Starting a new raid_dp RAID group;
The number of disks specified must be at least three
times the number of plexes in the target aggregate 'aggr0'.
fas2554-b>
I even tried this to no avail.
fas2554-b> sysconfig -r
Aggregate aggr0 (online, raid_dp, hybrid_enabled) (block checksums)
Plex /aggr0/plex0 (online, normal, active)
RAID group /aggr0/plex0/rg0 (normal, block checksums)
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity 0b.00.4 0b 0 4 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
parity 0b.00.6 0b 0 6 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.8 0b 0 8 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.10 0b 0 10 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.12 0b 0 12 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.14 0b 0 14 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.16 0b 0 16 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.18 0b 0 18 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
data 0b.00.20 0b 0 20 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block checksum
spare 0b.00.22 0b 0 22 SA:A 0 FSAS 7200 5614621/11498743808 5625872/11521787400
spare 0b.00.0 0b 0 0 SA:A 0 SSD N/A 381304/780910592 381554/781422768
spare 0b.00.2 0b 0 2 SA:A 0 SSD N/A 381304/780910592 381554/781422768
Partner disks
partner 0a.00.3 0a 0 3 SA:B 0 SSD N/A 0/0 381554/781422768
partner 0a.00.1 0a 0 1 SA:B 0 SSD N/A 0/0 381554/781422768
partner 0a.00.5 0a 0 5 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.7 0a 0 7 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.23 0a 0 23 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.21 0a 0 21 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.19 0a 0 19 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.17 0a 0 17 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.15 0a 0 15 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.13 0a 0 13 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.9 0a 0 9 SA:B 0 FSAS 7200 0/0 5625872/11521787400
partner 0a.00.11 0a 0 11 SA:B 0 FSAS 7200 0/0 5625872/11521787400
fas2554-b> aggr add aggr0 -g rg0 -d 0b.00.0
aggr add: Disk type does not match type of disks in the aggregate.
fas2554-b>
Not sure where I went wrong. I am running 7 mode. Any help would be appreciated it. Thanks!
