All,
I have a FAS3020 that isn't booting.
Here is what I am getting...any ideas to get this filer to boot?
NetApp Release 7.3.4: Thu May 27 17:52:48 PDT 2010
Copyright (c) 1992-2010 NetApp.
Starting boot on Fri Jul 13 18:34:03 GMT 2012
Fri Jul 13 18:34:46 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 0b.
Fri Jul 13 18:34:54 GMT [diskown.isEnabled:info]: software ownership has been enabled for this system
add net 127.0.0.Fr0: gateway 127.0i Jul 13 18:34:57 GMT [config.noPartnerDisks:CRITICAL]: No disks were detected for the partner; this node will be unable to takeover correctly
.0.1
Fri Jul 13 18:34:57 GMT [fmmb.current.lock.disk:info]: Disk 0a.18 is a local HA mailbox disk.
Fri Jul 13 18:34:57 GMT [fmmb.current.lock.disk:info]: Disk 0a.32 is a local HA mailbox disk.
Fri Jul 13 18:34:57 GMT [fmmb.instStat.change:info]: normal mailbox instance on local side.
Fri Jul 13 18:34:58 GMT [fmmb.instStat.change:info]: no mailbox instance on partner side.
Fri Jul 13 18:34:58 GMT [monitor.chassisPower.degraded:notice]: Chassis power is degraded:
Fri Jul 13 18:34:58 GMT [raid.assim.cls.outOfDate:error]: Orphaning Disk 0a.60 Shelf ? Bay ? [NETAPP X272_SCHT6073F10 NA16] S/N [3HZ7VJLV00007502BD5H] (21273/1351414276) in plex aggr0/0, because it is out-of-date (21607).
Fri Jul 13 18:34:58 GMT [raid.assim.cls.outOfDate:error]: Orphaning Disk 0a.42 Shelf ? Bay ? [NETAPP X272_HJURE073F10 NA14] S/N [41360296] (20851/1350424692) in plex aggr0/0, because it is out-of-date (21607).
Fri Jul 13 18:34:58 GMT [raid.assim.cls.outOfDate:error]: Orphaning Disk 0a.41 Shelf ? Bay ? [NETAPP X272_HJURE073F10 NA14] S/N [41360830] (20965/1350435816) in plex aggr0/0, because it is out-of-date (21607).
Root volume is failed (all disks may not yet be visible).
Rebooting... (ctrl-c to break reboot loop)
