Don't have an account?
ONTAP Hardware
Hi
Can some one help me understand what should be the OLTP response standard.
like for reads it can be <7 ms
or
for Write ❤️
i will need these metrices to measure if the response is met or not.|
i think you can try to find these netapp technical reports about database performance.
http://www.netapp.com/us/library/
go above location and search
hopefully helps
Jeff
Did you know you can receive a notification when new software releases are published to the NetApp Support Site?
Join our Discord Community
