Subscribe
Highlighted
Accepted Solution
Performance issue on 3240 HA 7mode
I have a ticket open with Netapp but wanted to get feedback on what is to be expected performance.
We recently spent some bucks on getting a SSD shelf with 24x 200GB SSD's for our 3240 pair.  The SSD are the Samsung eMLC ones. We're running 8.1.2p3
We can't seem to get any real performance out of them.
Iops wise, we are only able to max out at about 35-40K.  I would of expected at least 80K+
I'm using IOMETER with: 4K transfer - 100% Random distribution - 100% Read - 4K aligned IO
Then trying to tranfer 16MB chunks we get about 380MB/s transfer rates.  22-23 iops.  I would of expected a bit more.  atleast 600MB writing to the rg.
it's a 23 disk RG running raid DP.
The box uses iscsi and NFS.   In this instance, I am accessign the disks via a VMWare VM using the MS initiator.   I've tried RDM's, and NFS.   RDM performance is pretty par with and MS initiator within the VM..
NFS suffers from even worse performance.
The network is 10Gb.  Inside the esxi boxes i have the Intel x520DA nic and Cisco Nexus 5548 switches conenction the boxes to the filers.
Any thoughts on this would be helpful.   So far, after sending in some perfstats, NetApp tech support has stated that they don't see anything out of the ordinary.
I say there isn't anything out of the ordinary.  It just that we are not seeing the performance we should see out of the disks.
Again, any help would be greatly appreaciated.
Larry
Re: Performance issue on 3240 HA 7mode
Hi Larry,
I'm not saying it will solve anything and you might have looked into that already, but can you run "sysstat -x 2" whilst doing throughput tests & post the results here?
Maybe CPU gets hammered so heavily that it becomes the bottleneck?
Regards,
Radek
Have you applied best practices on both - the shelf cabling and vmware configuration? Also, go over 10gig network configuration, I have experienced issues between storage and ESXi hosts in 10gig ethernet. VSC helps somewhat but, performance tuning in 10gig ethernet always requires some effort. SSD shelf should be cabled in separate stack or at least be the first one in stack.
Best regards,
Timo
We had another SAS controller installed on the 3240 for the SSD.  We cabled up the SSD shelf to it.  I also added another SAS shelf and cabled it to the SAS controller to it.  The SAS shelf current sits empty. I only have data on the SSD's at this time.
The esxi server are cabled correctly to the switches.   I have verified throughput.  I can saturate the each link to about 9.5GBps.   I removed any network control IO for testing of the ESXi servers.   I can vmotion a server from one ESXi server to another, in record time.  I can see the nics transferring between servers and hitting 8+ GBps.  Granted it goes from the RAM on one server to the RAM of another, but it verifies that the network can handle and put through a lot of data.
I've tweaked nics.  Flowcontrol off, jumbo frames, receive windows sizes. U name it.
Switches have MTU set to 9216, They do not report any error frames, no re-transmits, Nothing.  Clean as a whistle.
Larry
Normal output without any load testing from IO meter.
sysstat -x 2
CPU    NFS   CIFS   HTTP   Total     Net   kB/s    Disk   kB/s    Tape   kB/s  Cache  Cache    CP  CP  Disk   OTHER    FCP  iSCSI     FCP   kB/s   iSCSI   kB/s
                                       in    out    read  write    read  write    age    hit  time  ty  util                            in    out      in    out
22%   2213     57      0    3694   12493  12161   10472     12       0      0     0s    92%    0%  -    12%       0      0   1424       0      0    5644   1642
32%   2247     34      0    4457   12787  80785    9498     16       0      0     1     98%    0%  -    11%     357      0   1819       0      0    5125  72024
33%   2089     61      0    4284   11490  71957    9942      0       0      0     0s    98%    0%  -    11%     248      0   1886       0      0    5203  61249
28%   1566     22      0    4634   22631  46895    8652     12       0      0     1     98%    0%  -     7%     760      0   2286       0      0   16354  36091
44%   3079      5      0    5170   11831  50114   32710  11490       0      0     1     98%   33%  Tf   16%       3      0   2083       0      0    3593  37095
34%   5582     17      0    6510   22378  26915   25053  47656       0      0    58s    95%  100%  :f   23%     195      0    716       0      0    4167  16564
27%   5510      2      0    6563    7442  20225   10656  51356       0      0    58s    96%  100%  :f   14%     624      0    427       0      0    1495   7045
28%   7703      5      0    8060    6061  17982    7216  27056       0      0     0s    94%   50%  :    10%     225      0    127       0      0      91   8389
29%   4417      9      0    5044   15395  56754    8402      0       0      0    52s    98%    0%  -     7%      44      0    574       0      0     558  46404
25%   2059     27      0    3319    8529  76749    8176     16       0      0     0s    98%    0%  -     7%       5      0   1228       0      0     226  63087
34%   2252     20      0    3256    9665  81286   12370     12       0      0    55s    97%    0%  -    17%     204      0    780       0      0    3028  61723
40%   3320      5      0    4152   19817  92174    8836      4       0      0    49s    98%    0%  -    15%       3      0    824       0      0   10454  73855
43%   1970      8      0    2610    9599  59711   46786  59622       0      0    46s    97%   50%  Tf   29%       0      0    632       0      0    4496  46047
23%   2824      0      0    3076    5056  42455   19338  47264       0      0    46s    96%  100%  :f   25%       1      0    251       0      0     162  21742
28%   4752      3      0    5101    7774  57057   11126  20228       0      0     1s    97%   55%  :    20%       3      0    343       0      0     175  33071
28%   3462      6      0    4665   31596  52672   13554     12       0      0     1s    96%    0%  -    22%       0      0   1197       0      0   23282  29078
26%   5244      3      0    5618   11236  38894   11504     16       0      0     0s    95%    0%  -    18%       3      0    368       0      0     134  19120
22%   3690      3      0    3866    5281  54532   34416      0       0      0    51s    93%    0%  -    22%       0      0    173       0      0     117  18100
26%   3771      6      0    4812    6211  58189   15632     12       0      0    44s    96%    0%  -    20%     709      0    326       0      0     132  31613
Load output IO Meter:   Transfer Request Size 4K - 100% Random Access - 100% Access Specification - 100% Read Distribution - 4K Aligned IO
sysstat -x 2
87%   3494     11      0   43814   16150 205181  127896      4       0      0     7s    45%    0%  -    41%       2      0  40307       0      0    6511 189587
86%   2931     20      0   42097   13529 219815  122402     12       0      0     6s    50%    0%  -    40%       0      0  39146       0      0    6315 205359
88%   3699    162      0   41929    8958 230617  119240     16       0      0     6s    58%    0%  -    40%       3      0  38065       0      0     146 213639
88%   2525     54      0   38680    6422 227492  120333    637       0      0     6s    60%   11%  Tn   40%       0      0  36101       0      0     188 215957
88%   2678     47      0   40523    6426 195799  144529  51259       0      0     6s    50%  100%  :f   41%      47      0  37751       0      0     142 177521
88%   4158     66      0   43367   11776 196611  136788  35372       0      0     7s    49%  100%  :f   41%       3      0  39140       0      0    1969 179757
87%   3595     31      0   41575   20804 173151  117057  27068       0      0     0s    44%   82%  :    40%      11      0  37938       0      0    4732 157339
87%   2551      1      0   43810   27262 183591  120958     16       0      0     7s    46%    0%  -    40%      50      0  41208       0      0   19916 170101
89%   3288     15      0   43064   14393 225702  116794     12       0      0     6s    56%    0%  -    38%      16      0  39745       0      0    2820 213647
89%   2617     14      0   42945   13388 219565  118542      0       0      0     6s    51%    0%  -    40%      71      0  40243       0      0    4174 205255
89%   3873      3      0   40678   13350 250964  113674     16       0      0     6s    61%    0%  -    40%       5      0  36797       0      0    4759 231133
88%   2821     76      0   38778   10641 183914  126484   7266       0      0     6s    55%   18%  Tn   40%      13      0  35868       0      0    2960 166863
88%   2579      0      0   39427   21474 165066  133378  57494       0      0     6s    46%  100%  :f   41%       4      0  36844       0      0   12661 151652
87%   1904     34      0   43533    7382 184509  129775  45741       0      0     6s    38%  100%  :f   44%       0      0  41595       0      0     193 173270
88%   6506     23      0   46367    7884 178743  122516   8570       0      0     6s    42%   26%  :    40%       0      0  39838       0      0     313 166676
89%   9307     26      0   43438    8633 229781  103372      4       0      0     6s    60%    0%  -    35%       2      0  34103       0      0     502 212554
88%   2742      1      0   37510    7216 275261  108126     12       0      0     7s    66%    0%  -    36%      30      0  34737       0      0     406 262300
88%   3928     21      0   45354    8067 209393  121533     16       0      0     7s    45%    0%  -    42%      16      0  41389       0      0     183 195308
87%   2885      2      0   46181    7296 193702  130646      0       0      0     6s    39%    0%  -    44%      19      0  43275       0      0     161 177334
Load output IO Meter:   Transfer Request Size 16MB - 100% Sequential Access - 100% Access Specification - 100% Read Distribution - 4K Aligned IO
68%   4672      0      0    7325    8923 354433  265440  43280       0      0    18s    99%  100%  :f   40%     277      0   2376       0      0     138 342716
59%   3335     15      0    5369    6449 344757  217788  32070       0      0    19s    99%  100%  :f   35%      53      0   1966       0      0     254 335380
57%   3500      0      0    4901    7972 317931  248322   7686       0      0     0s    99%   35%  :    21%       0      0   1401       0      0     173 307724
54%   3134     27      0    4504    4627 317465  260380     12       0      0     0s    99%    0%  -    20%       4      0   1339       0      0     233 296178
68%   4477      1      0    6348    6669 388156  267822      0       0      0    16s    98%    0%  -    18%       0      0   1870       0      0     735 345821
63%   5636      1      0    7556   10006 322534  240190     16       0      0    13s    98%    0%  -    22%     139      0   1780       0      0    2289 297738
61%   3532      4      0    6155    8938 341386  272162     12       0      0     0s    99%    0%  -    14%       0      0   2619       0      0    3211 320131
74%   4689      8      0    7379   37665 304690  262102  34879       0      0    10s    98%   64%  Tf   37%       0      0   2682       0      0   20509 282759
61%   3424      3      0    5363    4557 341655  223644  40968       0      0     0s    99%  100%  :f   28%       3      0   1933       0      0     151 329314
64%   8645      1      0   10877    7107 340460  237286   8582       0      0   >60     99%   32%  :    17%     163      0   2068       0      0     141 326623
68%   9420      1      0   11683    8492 369522  238942      4       0      0    10s    99%    0%  -    19%     106      0   2156       0      0     204 351236
72%   5876   1614      0   10152   10516 342719  273166     12       0      0     0s    98%    0%  -    19%     391      0   2271       0      0    3183 317886
83%   7691   2922      0   12396   11209 316906  255950     16       0      0     0s    98%    0%  -    19%     247      0   1536       0      0    2116 300319
75%   8573     89      0   10173   47169 319148  256336      0       0      0    13s    98%    0%  -    16%      34      0   1477       0      0   13296 275942
78%   7118      7      0    8790   25555 246300  251986  37842       0      0    12s    98%   68%  Tf   29%     283      0   1382       0      0   17348 235860
72%   9251     20      0   10711   22171 291877  290006  52854       0      0    11s    98%  100%  :f   26%       3      0   1437       0      0   12895 278790
75%   7697     36      0    9586   20737 344585  246794  43434       0      0     0s    98%  100%  :f   34%       0      0   1853       0      0   11778 328419
72%   8014      7      0   10487   25278 321429  266278   7918       0      0    14s    98%   33%  :    28%       0      0   2466       0      0   15352 306345
74%   8510      6      0   10168   29228 298529  285692     12       0      0    13s    98%    0%  -    24%       3      0   1649       0      0   15079 287470
75%   7305      0      0    8715   20279 277713  247068  33339       0      0    12s    98%   41%  Ms   26%       0      0   1410       0      0   12825 260506
Can you also send the output of the "sysstat -M 2" command? You will need to run the "priv set diag" command in order to access the "-M" sysstat argument.
Thanks,
Dan
Dan below are the reading for the same exact load scenarios above.
sysstat -M 2
ANY1+ ANY2+ ANY3+ ANY4+  AVG CPU0 CPU1 CPU2 CPU3 Network Protocol Cluster Storage Raid Target Kahuna WAFL_Ex(Kahu) WAFL_XClean SM_Exempt Cifs Exempt Intr Host  Ops/s   CP
  46%   15%    4%    1%  22%  21%  25%  23%  20%     24%       0%      0%      2%   1%     4%     9%     23%( 20%)          0%        0%   0%     3%   8%  14%   4435   0%
  39%   12%    4%    1%  18%  18%  20%  19%  16%     18%       0%      0%      1%   1%     2%     8%     20%( 16%)          0%        0%   0%     4%   6%  14%   4374   0%
  55%   21%    8%    4%  27%  25%  28%  27%  28%     27%       0%      0%      1%   2%     3%    14%     35%( 25%)          2%        0%   0%     4%   7%  13%   5973   4%
  61%   39%   28%   16%  39%  39%  40%  39%  38%     22%       0%      0%      5%  10%     3%    11%     67%( 38%)          7%        0%   0%    17%   6%   9%   4340  93%
  17%    5%    1%    0%   9%  10%  11%   9%   5%      8%       0%      0%      1%   1%     2%     2%      7%(  7%)          0%        0%   0%     3%   4%   6%   1023   0%
  31%   12%    4%    1%  15%  16%  18%  16%  10%     15%       0%      0%      1%   1%     3%     2%     19%( 15%)          0%        0%   0%     6%   4%   9%   2101   0%
  26%    9%    4%    1%  13%  13%  15%  13%   8%     12%       0%      0%      1%   1%     2%     2%     16%( 12%)          0%        0%   0%     5%   4%   8%   2303   0%
  21%    6%    1%    0%  10%  11%  11%  10%   5%     10%       0%      0%      1%   1%     1%     2%      9%(  8%)          0%        0%   0%     3%   5%   7%   2152   0%
  25%   10%    5%    2%  14%  14%  15%  16%  11%     10%       0%      0%      1%   2%     1%     4%     18%( 13%)          4%        0%   0%     2%   4%  10%   2498   5%
  40%   18%    8%    4%  20%  21%  22%  20%  15%     11%       0%      0%      4%   6%     2%     4%     26%( 18%)          4%        0%   0%    10%   5%   7%   2166 100%
  35%   15%    8%    4%  19%  21%  22%  21%  13%     14%       0%      0%      2%   4%     2%     4%     24%( 14%)          0%        0%   0%    10%   4%  11%   2310 100%
  34%   10%    3%    1%  15%  15%  17%  15%  13%     17%       0%      0%      1%   1%     1%     5%     19%( 15%)          0%        0%   0%     4%   4%   8%   4411   4%
  59%   24%    7%    1%  29%  31%  34%  32%  20%     34%       0%      0%      1%   1%     5%     6%     30%( 27%)          0%        0%   0%    11%   9%  19%   5179   0%
  42%   19%   10%    5%  22%  23%  24%  23%  19%     21%       0%      0%      1%   1%     5%     6%     32%( 22%)          0%        0%   0%     7%   6%  10%   5011   0%
  26%    8%    2%    0%  13%  13%  15%  15%   8%     12%       0%      0%      1%   1%     2%     3%     13%( 11%)          0%        0%   0%     4%   5%  11%   1942   0%
  33%   11%    3%    1%  16%  17%  19%  17%  11%     16%       0%      0%      2%   1%     2%     4%     17%( 14%)          0%        0%   0%     4%   4%  13%   3190   0%
  48%   25%   13%    6%  28%  29%  30%  28%  24%     12%       0%      0%      3%   6%     1%     7%     37%( 25%)          7%        0%   0%    15%   5%  16%   2588  96%
  26%    9%    3%    1%  12%  13%  14%  12%  10%     10%       0%      0%      2%   2%     1%     4%     15%( 11%)          0%        0%   0%     6%   3%   7%   2058  63%
  26%    8%    3%    1%  12%  12%  14%  12%  10%     12%       0%      0%      1%   1%     2%     4%     13%( 11%)          0%        0%   0%     3%   3%   8%   2545   0%
  32%   10%    3%    0%  17%  19%  19%  20%   9%     14%       0%      0%      2%   1%     2%     3%     15%( 13%)          0%        0%   0%     7%   5%  18%   2154   0%
  26%    9%    3%    1%  14%  13%  17%  16%   9%     14%       0%      0%      1%   1%     1%     3%     15%( 12%)          0%        0%   0%     3%   7%  10%   2739   0%
  31%   10%    3%    1%  15%  14%  18%  18%   9%     16%       0%      0%      1%   1%     3%     2%     16%( 13%)          0%        0%   0%     5%   6%  10%   2548   0%
sysstat -M 2
  98%   96%   88%   60%  89%  94%  94%  94%  75%     54%       0%      0%     27%  28%    38%     5%    160%( 85%)          4%        0%   0%    21%   8%  12%  37527   9%
100%   96%   87%   59%  88%  90%  93%  94%  75%     55%       0%      0%     26%  28%    38%     9%    153%( 81%)          2%        0%   0%    22%   8%   9%  37439 100%
100%   96%   87%   60%  89%  91%  94%  95%  74%     59%       0%      0%     27%  27%    42%     6%    157%( 83%)          0%        0%   0%    18%   9%  10%  41271  47%
  98%   94%   83%   54%  85%  89%  91%  92%  69%     55%       0%      0%     30%  29%    44%     5%    148%( 82%)          0%        0%   0%    14%   7%  10%  42856   0%
  96%   87%   69%   40%  77%  81%  80%  81%  63%     48%       0%      0%     26%  25%    39%     9%    128%( 73%)          0%        0%   0%    13%   8%  12%  35268   0%
  98%   95%   84%   55%  86%  89%  90%  92%  72%     54%       0%      0%     29%  28%    43%     8%    148%( 81%)          0%        0%   1%    14%   7%  10%  41983   0%
100%   97%   87%   58%  88%  93%  93%  94%  72%     56%       0%      0%     27%  27%    43%     5%    155%( 84%)          0%        0%   0%    21%   8%   9%  41240   0%
100%   96%   87%   59%  88%  92%  92%  93%  74%     46%       0%      0%     25%  30%    34%     7%    154%( 82%)         12%        0%   0%    27%   8%   8%  32501  97%
  99%   96%   86%   58%  88%  90%  93%  95%  72%     52%       0%      0%     25%  28%    39%     6%    152%( 82%)          0%        0%   0%    33%   8%   9%  36090 100%
  99%   92%   79%   50%  83%  85%  87%  90%  70%     50%       0%      0%     25%  25%    38%     7%    146%( 80%)          0%        0%   0%    21%   8%  11%  35440  37%
  97%   89%   74%   45%  79%  84%  84%  85%  63%     51%       0%      0%     26%  25%    40%     6%    136%( 76%)          0%        0%   0%    14%   8%  10%  37979   0%
  97%   89%   76%   48%  81%  85%  86%  87%  66%     58%       0%      0%     25%  24%    39%     6%    137%( 77%)          0%        0%   0%    14%   9%  11%  38628   0%
  98%   95%   83%   53%  87%  91%  92%  93%  70%     67%       0%      0%     24%  23%    40%     6%    145%( 80%)          0%        0%   0%    18%   9%  14%  40987   0%
  99%   95%   86%   58%  88%  92%  93%  93%  73%     63%       0%      0%     26%  25%    43%     7%    150%( 82%)          0%        0%   0%    18%   9%  10%  42561   0%
  99%   93%   83%   55%  85%  90%  90%  90%  71%     56%       0%      0%     24%  26%    39%     7%    145%( 80%)         10%        0%   0%    17%   8%   9%  36158  62%
100%   97%   88%   59%  89%  92%  94%  96%  74%     60%       0%      0%     27%  29%    43%     6%    151%( 84%)          0%        0%   0%    20%   9%  12%  40758 100%
100%   96%   86%   57%  87%  91%  92%  94%  72%     57%       0%      0%     27%  28%    45%     6%    150%( 82%)          0%        0%   0%    17%   8%  10%  43335  77%
  99%   95%   84%   54%  86%  89%  91%  94%  69%     58%       0%      0%     27%  26%    45%     5%    148%( 84%)          0%        0%   0%    14%   9%  10%  44552   0%
  99%   96%   86%   57%  87%  91%  93%  95%  71%     59%       0%      0%     24%  24%    43%     4%    153%( 83%)          0%        0%   0%    24%   8%  10%  40607   0%
  99%   95%   84%   55%  87%  90%  92%  94%  71%     56%       0%      0%     27%  26%    45%     5%    150%( 84%)          0%        0%   0%    18%   7%  12%  43312   0%
100%   94%   83%   53%  86%  88%  92%  94%  69%     55%       0%      0%     28%  27%    46%     5%    146%( 84%)          0%        0%   0%    14%   9%  13%  44818   0%
  98%   95%   84%   56%  86%  89%  91%  92%  71%     51%       0%      0%     26%  27%    41%     6%    152%( 83%)          8%        0%   0%    18%   6%   9%  40446  22%
  99%   95%   82%   53%  85%  88%  90%  92%  69%     53%       0%      0%     27%  29%    43%     6%    143%( 80%)          0%        0%   0%    21%   8%   9%  40301 100%
100%   95%   85%   55%  87%  90%  92%  95%  70%     57%       0%      0%     26%  26%    44%     6%    148%( 83%)          0%        0%   0%    21%   9%  10%  41948  47%
  98%   95%   83%   51%  86%  90%  93%  93%  70%     55%       0%      0%     27%  26%    46%     4%    146%( 81%)          0%        0%   0%    18%   7%  16%  43190   0%
  97%   93%   79%   48%  83%  87%  89%  91%  65%     49%       0%      0%     29%  27%    48%     3%    141%( 76%)          0%        0%   0%    17%   6%  14%  41486   0%
  97%   94%   81%   52%  84%  88%  90%  93%  66%     50%       0%      0%     30%  29%    50%     3%    141%( 77%)          0%        0%   0%    14%   8%  12%  44740   0%
  98%   93%   80%   51%  83%  87%  89%  92%  65%     50%       0%      0%     30%  27%    50%     3%    143%( 77%)          0%        0%   0%    13%   8%   9%  44529   0%
  98%   94%   83%   54%  85%  90%  91%  92%  68%     52%       0%      0%     27%  27%    45%     4%    145%( 79%)          5%        0%   0%    19%   8%   9%  41277  52%
  99%   94%   83%   54%  85%  89%  91%  94%  67%     52%       0%      0%     29%  27%    49%     3%    145%( 78%)          0%        0%   0%    19%   8%   9%  43466  31%
  99%   95%   83%   55%  86%  90%  91%  92%  70%     53%       0%      0%     28%  26%    48%     4%    148%( 79%)          0%        0%   0%    18%   8%  11%  42859   0%
100%   96%   86%   57%  88%  92%  94%  96%  70%     58%       0%      0%     28%  26%    48%     4%    151%( 80%)          0%        0%   0%    19%   9%  12%  44058   0%
  97%   90%   76%   47%  81%  85%  86%  88%  64%     50%       0%      0%     28%  26%    46%     4%    138%( 75%)          0%        0%   0%    13%   8%  11%  41602   0%
  99%   95%   82%   53%  85%  88%  91%  93%  67%     50%       0%      0%     30%  28%    52%     3%    146%( 78%)          0%        0%   0%    13%   8%   9%  46371   0%
  99%   95%   83%   51%  87%  90%  91%  94%  71%     46%       0%      0%     27%  27%    42%     5%    146%( 79%)          5%        0%   0%    23%   8%  16%  37623  69%
  98%   94%   81%   52%  85%  89%  91%  92%  66%     49%       0%      0%     31%  28%    51%     3%    143%( 77%)          0%        0%   0%    15%   6%  12%  45390  30%
  99%   95%   83%   54%  85%  89%  92%  94%  67%     53%       0%      0%     29%  27%    50%     3%    147%( 79%)          0%        0%   0%    14%   8%   9%  46035   0%
  98%   95%   84%   55%  86%  90%  92%  93%  67%     55%       0%      0%     24%  22%    43%     3%    148%( 79%)          0%        0%   0%    30%   7%  10%  37164   0%
sysstat -M 2
  81%   54%   32%   14%  49%  52%  54%  52%  38%     32%       0%      0%     10%  15%    13%     5%     70%( 49%)          5%        0%   0%    27%   7%  12%   1984  87%
  82%   53%   27%   10%  47%  50%  52%  52%  34%     37%       0%      0%     10%  12%    14%     3%     66%( 49%)          0%        0%   0%    25%   9%  13%   3036  21%
  85%   57%   30%   10%  50%  54%  56%  54%  37%     39%       0%      0%     11%  13%    15%     3%     70%( 52%)          0%        0%   0%    27%   8%  16%   2823   0%
  88%   63%   38%   16%  57%  61%  62%  63%  40%     52%       0%      0%      8%  11%    17%     3%     79%( 55%)          0%        0%   0%    29%  11%  17%   6541   0%
  86%   56%   31%   12%  52%  54%  56%  59%  37%     49%       0%      0%      7%  10%    15%     4%     70%( 50%)          0%        0%   0%    24%  10%  17%   6688   0%
  77%   43%   20%    7%  41%  44%  45%  47%  28%     35%       0%      0%      7%  10%    13%     3%     55%( 43%)          0%        0%   0%    21%   8%  13%   3013   0%
  86%   60%   36%   16%  54%  56%  59%  61%  39%     39%       0%      0%      9%  14%    14%     4%     77%( 53%)          5%        0%   0%    31%   9%  13%   3362  69%
  82%   53%   27%    9%  48%  51%  54%  54%  32%     41%       0%      0%      7%  10%    15%     3%     66%( 49%)          0%        0%   0%    25%   9%  15%   3608   0%
  82%   55%   31%   13%  50%  52%  54%  56%  38%     41%       0%      0%      8%  11%    16%     4%     73%( 52%)          0%        0%   0%    24%   9%  14%   4441   0%
  82%   51%   28%   10%  49%  52%  54%  57%  35%     41%       0%      0%      7%  10%    16%     4%     65%( 48%)          0%        0%   0%    24%   9%  21%   3778   0%
  78%   47%   22%    6%  43%  45%  47%  50%  30%     38%       0%      0%      7%   9%    14%     3%     58%( 45%)          0%        0%   0%    20%   8%  14%   3394   0%
  90%   74%   55%   31%  66%  68%  71%  70%  55%     44%       0%      0%      9%  16%    14%     7%    110%( 64%)         13%        0%   0%    32%   7%  11%   3786  79%
  88%   63%   39%   16%  56%  58%  62%  64%  40%     42%       0%      0%      8%  14%    16%     6%     77%( 52%)          0%        0%   0%    37%  10%  15%   2887 100%
  87%   60%   35%   15%  53%  57%  59%  60%  38%     39%       0%      0%      8%  12%    15%     4%     78%( 52%)          0%        0%   0%    34%   9%  13%   3062 100%
  87%   61%   36%   15%  55%  58%  59%  61%  41%     47%       0%      0%      7%   9%    15%     5%     81%( 54%)          0%        0%   0%    28%  11%  16%   4186  13%
  79%   51%   27%   10%  46%  49%  52%  52%  32%     42%       0%      0%      8%  10%    14%     3%     63%( 48%)          0%        0%   0%    23%   7%  14%   3755   0%
  78%   47%   23%    8%  43%  47%  47%  49%  30%     40%       0%      0%      7%   9%    13%     4%     58%( 44%)          0%        0%   0%    19%   8%  14%   3670   0%
  79%   45%   20%    5%  43%  46%  48%  50%  28%     39%       0%      0%      7%   9%    14%     3%     54%( 43%)          0%        0%   0%    19%   8%  20%   3212   0%
  88%   61%   35%   13%  55%  57%  61%  64%  38%     50%       0%      0%      7%   9%    18%     3%     75%( 54%)          0%        0%   0%    29%  11%  17%   4536   0%
  88%   66%   41%   18%  58%  61%  64%  65%  43%     46%       0%      0%     10%  14%    15%     5%     82%( 56%)          5%        0%   0%    30%  10%  14%   4534  86%
  81%   49%   23%    7%  45%  47%  51%  53%  30%     40%       0%      0%      7%   9%    14%     3%     59%( 46%)          0%        0%   0%    22%  10%  17%   3922   0%
  79%   47%   23%    8%  44%  48%  48%  50%  30%     39%       0%      0%      7%   9%    14%     3%     61%( 46%)          0%        0%   0%    20%   8%  14%   4153   0%
  81%   50%   25%    8%  46%  50%  50%  51%  32%     39%       0%      0%      9%  11%    14%     4%     63%( 48%)          0%        0%   0%    22%   8%  14%   3717   0%
  80%   51%   25%    8%  47%  50%  52%  55%  31%     44%       0%      0%      7%   9%    15%     3%     62%( 47%)          0%        0%   0%    21%   9%  18%   5134   0%
  81%   53%   28%   10%  49%  52%  54%  56%  33%     43%       0%      0%      7%   8%    17%     3%     66%( 48%)          0%        0%   0%    25%   8%  18%   3412   0%
  87%   63%   38%   16%  56%  59%  62%  61%  42%     41%       0%      0%     10%  14%    15%     5%     79%( 55%)          4%        0%   0%    31%  10%  15%   2404  84%
  80%   48%   24%    8%  44%  47%  48%  51%  30%     37%       0%      0%      8%  10%    14%     3%     61%( 45%)          0%        0%   0%    22%   8%  13%   3115   0%
  75%   44%   20%    6%  41%  43%  45%  48%  28%     35%       0%      0%      8%  10%    13%     3%     55%( 43%)          0%        0%   0%    20%   8%  12%   2530   0%
  84%   56%   29%   10%  50%  52%  54%  55%  37%     45%       0%      0%      9%  10%    14%     5%     71%( 51%)          0%        0%   0%    21%   8%  15%   5269   0%
  79%   49%   24%    8%  44%  47%  49%  50%  33%     41%       0%      0%      7%   9%    14%     5%     63%( 47%)          0%        0%   0%    19%   7%  14%   4368   0%
  81%   52%   28%   11%  49%  51%  54%  56%  35%     40%       0%      0%      8%  11%    15%     5%     64%( 47%)          5%        0%   0%    21%  10%  18%   2359  13%
  79%   49%   26%    9%  45%  48%  50%  51%  31%     36%       0%      0%      8%  12%    14%     4%     61%( 44%)          0%        0%   0%    24%   7%  14%   2984  90%
  78%   46%   22%    6%  43%  48%  47%  48%  30%     34%       0%      0%      7%  10%    14%     3%     59%( 44%)          0%        0%   0%    22%   8%  16%   2088   0%
  86%   60%   34%   12%  54%  57%  60%  62%  37%     51%       0%      0%      7%  10%    16%     3%     74%( 53%)          0%        0%   0%    26%  10%  17%   6267   0%
  85%   58%   32%   12%  53%  56%  58%  59%  36%     51%       0%      0%      7%   9%    15%     4%     73%( 51%)          0%        0%   0%    24%  10%  17%   6826   0%
Thanks,
Larry
CPU seems to be quite heavily hammered during tests - it definitely doesn't help with overall performance.
I appreciate this statement not necessarily brings us any closer to a solution.
Hmm ... your stats show that real IO size is much less, sounds more like 256KB. Probably it gets split at OS level. This could have impact on throughput. May be it is limited by vmfs block size?
But your tests are pure read, not write?
Not using VMFS.   The OS is Windows 2012 on NFS. I have the MS initiator going inside of the VM.   It's an iSCSI lun.
I have not posted any write results, as my read result are pretty poor.
Here are the stats with writes:
Load output IO Meter:   Transfer Request Size 4K - 100% Random Access - 100% Access Specification - 50% Read/Write Distribution - 4K Aligned IO
sysstat -M 2
  99%   97%   93%   72%  92%  95%  96%  96%  83%     46%       0%      0%     17%  25%    33%     8%    180%( 86%)         14%        0%   0%    32%   5%   7%  34423  78%
100%   97%   93%   72%  93%  94%  96%  97%  82%     50%       0%      0%     16%  20%    38%     4%    191%( 89%)         10%        0%   0%    26%   7%   7%  38359  24%
100%   99%   94%   70%  93%  96%  96%  98%  84%     51%       0%      0%     17%  21%    39%     7%    187%( 87%)          2%        0%   0%    32%   7%   9%  38974  73%
100%   97%   92%   71%  92%  95%  96%  95%  81%     48%       0%      0%     17%  24%    34%     6%    179%( 87%)         14%        0%   0%    31%   7%   7%  34195  61%
  99%   98%   94%   74%  93%  96%  97%  97%  83%     58%       0%      0%     15%  16%    40%     4%    195%( 89%)          0%        0%   0%    31%   6%   7%  39043  22%
  95%   89%   82%   64%  85%  86%  89%  88%  77%     42%       0%      0%     14%  21%    30%     8%    166%( 80%)         13%        0%   0%    34%   5%   7%  28180  85%
100%   97%   93%   72%  93%  94%  96%  98%  82%     49%       0%      0%     17%  20%    39%     5%    192%( 89%)          7%        0%   0%    28%   7%   7%  38026  82%
100%   99%   93%   72%  93%  96%  96%  98%  83%     46%       0%      0%     17%  24%    38%     6%    186%( 89%)          8%        0%   0%    34%   7%   7%  36300 100%
  99%   97%   93%   72%  92%  94%  96%  96%  82%     46%       0%      0%     18%  24%    38%     6%    185%( 87%)         13%        0%   0%    28%   5%   7%  36161  63%
100%   97%   93%   70%  93%  96%  96%  96%  82%     51%       0%      0%     17%  18%    43%     5%    194%( 88%)          0%        0%   0%    27%   7%   9%  40822  47%
100%   97%   92%   72%  92%  94%  96%  97%  82%     44%       0%      0%     16%  23%    34%     6%    183%( 88%)         14%        0%   0%    35%   7%   7%  31835  96%
  96%   89%   81%   61%  84%  86%  88%  87%  75%     43%       0%      0%     13%  17%    29%     6%    168%( 81%)         12%        0%   0%    32%   7%   8%  26509  62%
100%   98%   93%   72%  93%  96%  96%  97%  82%     51%       0%      0%     17%  20%    39%     6%    188%( 87%)          1%        0%   0%    34%   7%   7%  37206 100%
  97%   90%   83%   61%  85%  88%  89%  88%  75%     38%       0%      0%     16%  25%    31%     7%    162%( 81%)         14%        0%   0%    31%   7%   9%  29662  78%
100%   97%   92%   70%  92%  94%  96%  97%  82%     49%       0%      0%     18%  20%    44%     4%    194%( 89%)          4%        0%   0%    18%   7%   9%  43704  30%
  95%   89%   82%   61%  84%  86%  87%  88%  77%     42%       0%      0%     16%  22%    32%     8%    165%( 80%)          9%        0%   0%    29%   5%   9%  31094  70%
100%   97%   93%   74%  93%  96%  96%  96%  84%     49%       0%      0%     16%  22%    39%     6%    194%( 90%)         13%        0%   0%    20%   7%   7%  39797  46%
100%   97%   91%   68%  92%  95%  96%  96%  80%     52%       0%      0%     18%  20%    44%     5%    186%( 86%)          0%        0%   0%    25%   7%  10%  42503  76%
  99%   96%   90%   67%  91%  94%  95%  94%  82%     43%       0%      0%     15%  23%    29%     7%    172%( 86%)         14%        0%   0%    43%   7%  12%  27077  93%
Load output IO Meter:   Transfer Request Size 4K - 100% Random Access - 100% Access Specification - 100% Write Distribution - 4K Aligned IO
sysstat -M 2
100%   98%   93%   73%  93%  95%  96%  96%  86%     52%       0%      0%      8%  16%    32%     7%    197%( 89%)         13%        0%   0%    30%   7%  10%  33940  86%
100%   98%   93%   73%  94%  96%  96%  97%  85%     52%       0%      0%      7%  15%    32%     7%    195%( 89%)         12%        0%   0%    37%   7%   8%  30657  73%
100%   96%   92%   72%  92%  92%  95%  96%  86%     51%       0%      0%      7%  13%    33%     7%    202%( 91%)         12%        0%   0%    29%   7%   8%  34257  68%
  99%   97%   92%   69%  93%  93%  95%  96%  88%     49%       0%      0%      7%  14%    32%     8%    200%( 90%)         13%        0%   0%    29%   6%  14%  33422  72%
100%   96%   91%   70%  92%  92%  94%  96%  87%     47%       0%      0%      7%  17%    32%     8%    195%( 90%)         17%        0%   0%    28%   7%  11%  33501  71%
  98%   91%   82%   58%  86%  86%  86%  89%  81%     48%       0%      0%      7%  13%    28%    10%    177%( 83%)         11%        0%   0%    27%   8%  12%  29985  63%
100%   99%   95%   74%  94%  95%  96%  97%  88%     48%       0%      0%      8%  18%    30%     8%    198%( 90%)         19%        0%   0%    33%   7%   7%  30909  82%
100%   97%   92%   72%  93%  93%  95%  96%  86%     52%       0%      0%      7%  15%    32%     7%    196%( 89%)         12%        0%   0%    34%   6%   8%  31736  79%
  99%   96%   90%   69%  92%  94%  95%  95%  84%     50%       0%      0%      7%  15%    31%     7%    190%( 88%)         13%        0%   0%    34%   7%  11%  30911  74%
100%   97%   92%   70%  93%  94%  96%  97%  85%     54%       0%      0%      6%  12%    36%     6%    203%( 91%)         11%        0%   0%    23%   7%  13%  38043  68%
  99%   97%   91%   69%  92%  94%  95%  95%  85%     54%       0%      0%      7%  13%    34%     7%    195%( 88%)         11%        0%   0%    28%   7%  13%  35664  74%
  98%   97%   91%   69%  92%  93%  95%  95%  85%     55%       0%      0%      7%  14%    34%     7%    193%( 88%)         15%        0%   0%    24%   7%  12%  35473  64%
100%   99%   94%   74%  94%  95%  96%  97%  88%     49%       0%      0%      8%  20%    30%     7%    195%( 91%)         22%        0%   0%    30%   5%   8%  32008  74%
100%   98%   93%   72%  93%  94%  96%  96%  87%     54%       0%      0%      7%  15%    35%     7%    199%( 89%)         13%        0%   0%    26%   6%   9%  36026  79%
100%   97%   92%   72%  93%  95%  95%  96%  86%     53%       0%      0%      8%  15%    33%     9%    195%( 87%)         12%        0%   0%    31%   8%  10%  33159  81%
100%   97%   92%   71%  93%  94%  96%  98%  84%     59%       0%      0%      6%  13%    33%     7%    191%( 89%)         12%        0%   0%    32%   8%  10%  31931  67%
  99%   97%   92%   72%  93%  94%  96%  96%  85%     57%       0%      0%      7%  14%    33%     7%    196%( 89%)         12%        0%   0%    29%   6%   9%  33729  74%
  96%   90%   82%   62%  86%  86%  88%  89%  79%     55%       0%      0%      7%  13%    27%     8%    178%( 83%)         12%        0%   0%    26%   6%  10%  31456  64%
  97%   90%   83%   63%  86%  87%  90%  91%  77%     57%       0%      0%      7%  13%    28%     7%    173%( 81%)         13%        0%   1%    29%   8%  10%  30854  71%
