To allow failover between heads in active/active pair each head must be up and running; and to be able to run, each head needs at least root volume. Your configuration leaves second head as cold spare. It could be acceptable if you can afford downtime for replacement (I had customers with single FAS250 or R200), but it is pretty expensive spares stock IMHO.
