Don't have an account?
Network and Storage Protocols
I know that SnapDrive software is a pre-req for other SnapManager products, but since there is not a SnapDrive for VMWare product, does this mean that SnapManger for VI can be licensed on the host without any SnapDrive?
Thank you.
Tom
Correct. SMVI does not depend on an underlying SnapDrive installation.
Joe,
Belated thanks for your answer.
It does require SnapRestore however and if you're using NFS you'll need FlexClone for the "datastore/vm test clone" functionality.
Did you know you can receive a notification when new software releases are published to the NetApp Support Site?
Join our Discord Community
