ONTAP Discussions
SnapManager for SQL SMSQL Backup and SnapMirror question about system databases
txskibum2000
I am configuring nightly scheduled SMSQL backups of a simple SQL Database Server (virtual).
I created a LUN for Databases, LUN for Logs, LUN for Snapinfo, LUN for SystemDatabases, and a LUN for TempDatabase...(via SnapDrive).
Question #1...
Seems the LUNs for "SystemDatabases" and "TempDatabase" are not being backed up, because I do not see any nightly Snapshot Copies taken.  But, when I first configured SMSQL Backup, it did take a snapshot of the SystemDatabases for one day, then nothing after that.  Im not receiving any notifications of a SMSQL Backup Failure.  Do I need to worry about taking backups of the SystemDatabases??
Question #2...
I have configured SnapMIRROR for All the LUNs mentioned above.  Within the SMSQL Verification, I have Snapmirror update enabled.  All the LUNs are mirroring successfully, except for the "SystemDatabases" and the "TempDatabase".  Should I worry about System and Temp Databases being mirrored?  Is this even necessary?  In a Disaster, would SQL rebuild the System and Temp Databases?
Thanks for your time.
Dale
2 REPLIES 2
radek_kubka
Hi Dale,
Does this help to answer your questions?
http://communities.netapp.com/message/27944#27944
Regards,
Radek
txskibum2000
Yes, this helps.  I do plan to rebuild the exact same instance in a DR situation, therefore I do want to mirror the System Databases.  Now, I need to figure out why its not always successfully mirroring.  Any advise?
