ONTAP Discussions
Vol split
alexander7
Hello All!
Does the command "vol split" cause a disruption on the volume that is split?
Thank you if you answer.
1 ACCEPTED SOLUTION
radek_kubka
Hi,
Have you really got any traditional mirrored volumes? (if not, then you should use aggr split)
As per man pages - the command will not do any harm to the volume:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel733/html/ontap/cmdref/man1/na_vol.1.htm
Regards,
Radek
2 REPLIES 2
radek_kubka
Hi,
Regards,
Radek
alexander7
Radek, thank you very much! I see I should use "aggr split".
