ONTAP Discussions
mount error 5 = Input/output error
jrpatrick
I have been getting familar with a demo NetApp 8.2.1 ClusterMode in our lab.  I was trying to do some SPEC testing over CIFS.  So I recently setup CIFS on one of the SVMs.  It seems similar for the most part as a CIFS server on 7-mode ONTAP.  However, from my Redhat 5.8 VM, I can't seem to mount the CIFS share I created.
I get this message on the client:
the complete output:
[root@llsfs01 /]# mount.cifs //192.168.1.159/cifstest /mnt2 --verbose -ouser=spec,password=spec123
mount.cifs kernel mount options: unc=//192.168.1.159\cifstest,ip=192.168.1.159,ver=1,user=spec,pass=********
Refer to the mount.cifs(8) manual page (e.g.man mount.cifs)
my system works fine doing a mount of a CIFS on 8.1.4P1 7-mode in the lab:
[root@llsfs01 /]# mount.cifs //llnsa03/spectest /mnt2 --verbose -ouser=spec,password=spec123
mount.cifs kernel mount options: unc=//llnsa03\spectest,ip=192.168.1.8,ver=1,user=spec,pass=********
//llnsa03/spectest on /mnt2 type cifs (rw,mand)
[root@llsfs01 /]#
Any ideas what this error means?
1 REPLY 1
brunopad87
Hi there, have you found a fix for that?
