ONTAP Hardware
Data Encryption on Netapp Storage
tfaraj
Hi,
I have got a FAS2552 Storage cluster mode, I need to know if the data on disk is encrypted by default.
If I enable dedupliction or compression does this operation encrypt the data as well ?
Thanks ,
Tarek
2 REPLIES 2
Sahana
Hi,
You can check teh encryption status using storage encryption disk show
Using deduplication and compression will not encrypt data.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
rymcc86
Hello,
You may also find this guide on Storage Encryption handy, there are a number of criteria to consider prior to enabling Disk Encryption including the compatibility of your ONTAP OS.
https://library.netapp.com/ecmdocs/ECMP1368696/html/GUID-02382557-47A9-4D9C-8D1B-3DA2E537B998.html
Deduplication and Compression help to minimise disk utilisation rather than security.
All the best,
Ryan
