ONTAP Hardware
FAS 2020 Java not enabled
DAVID_KEITH_HALL
I have a FAS 2020 running OnTap 7.3.7. No errors on the install but I ran it again just to make sure.
I can access it via Oncommand and it says Timed is disabled. I login via the console and run options timed.enabled on and it gives me a message saying that java is not enabled on this filer.
I map to C$ and in etc I don't see a java folder. Can I copy the contents of the java folder over to the problematic device and reboot to fix it? If not, what else can I try?
1 ACCEPTED SOLUTION
DAVID_KEITH_HALL
I ended up fixing this issue by copying the etc/java folder from another FAS2020 that was running the same version of OnTap. Rebooted the filer and it works.
3 REPLIES 3
aborzenkov
How did you install it? If through special menu, option 4, you additionally need to do "software install" of the same version to get vol0 content.
DAVID_KEITH_HALL
I installed it through software install via the console.
DAVID_KEITH_HALL
