ONTAP Hardware
Oracle RAC node restart on Controller takeover/giveback
INFORHUNTER
Oracle RAC11gR2 (ASM)
RHEL 5.8
FAS 3210
a two nodes Oracle RAC on RHEL 5.8.both 2 nodes will restart while halt a controller.
Oracle ASM lost diskgroup at that time and never recover in 200s(Oracle RAC default disktimeout)
At the same time,all my vmware esxi goes well.
here is my multipath configuration:
defaults {
flush_on_last_del     yes
max_fds     max
pg_prio_calc     avg
queue_without_daemon     no
user_friendly_names     no
multipaths {
        multipath {
                wwid                    360a9800064724935574a6b6a4c507176
                alias                   mpath1
                path_grouping_policy     multibus
        multipath {
                wwid                    360a98000647344414b5a6b6a4c366667
                alias                   mpath2
        multipath {
                wwid                    360a9800064724935574a6b6a4c516c6f
                alias                   mpath3
        multipath {
                wwid                    360a9800064724935574a6a4d46784166
                alias                   mpath4
        multipath {
                wwid                    360a98000647344414b5a6b6a424b7148
                alias                   mpath5
devices {
device {
vendor     "NETAPP"
product     "LUN"
path_grouping_policy     group_by_prio
getuid_callout          "/sbin/scsi_id -g -u -s /block/%n"
path_checker     directio
path_selector     "round-robin 0"
hardware_handler     "0"
failback     immediate
features     "1 queue_if_no_path"
prio_callout            "/sbin/mpath_prio_ontap /dev/%n"
rr_min_io     128
rr_weight     uniform
no_path_retry      fail
1 REPLY 1
INFORHUNTER
Open a case at Oracle,here is their reply:
In the process of storage controllers Takeover/Giveback,there will be a short time of I/O interruption(in my case is about 45s),on the Oracle RAC level,its diskgroups changed to a  umounted status .although the IO recovery in a short time,these Oracle diskgroup should mount manually.
