ONTAP Hardware
Using System Manager with V3140
highvailsys
Is there any support for using System Manager with V3140?  I'm running System Manager version 1.0.0.340 against a V3140 running ontap 7.3.1.1L1.
Thank you,
Chris Green
3 REPLIES 3
dwaghmare
V-series filers are not supported yet.
only supported systems are NetApp FAS20XX, FAS30XX, and FAS31XX storage systems running Data ONTAP 7.2.3  or later.
danielpr
Deepak is right. System Manager 1.0 doesn't support Vseries. You can find more information @ http://communities.netapp.com/message/10117#10117
Thanks
Daniel
highvailsys
Thanks for the info guys, hopefully they support it soon. Especially since marketing is pushing V Series as a way into new customer accounts.
