ONTAP Hardware
ifgrp delete Error NitroMgr PCP RPC Error ERROR
LUIGI_TAMAGNONE
Hi,
i can't delete a ifgrp, if i try from console i receive this error:
network port ifgrp delete -node xxx -ifgrp xxx
Error: command failed: Interface group remove failed (Failed to delete interface group. Network stack error:
NitroMgr PCP RPC Error ERROR.). Some member ports may have already been removed. To verify port
membership, use the "network port ifgrp show" command.
If i try from NetApp OnCommand System Manager 3.1.2 i receive this error:
Data ONTAP API Failed :Interface group remove failed (Failed to delete interface group. Network stack error: NitroMgr PCP RPC Error ERROR.). Some member ports may have already been removed. To verify port membership, use the "network port ifgrp show" command. (Error: 13001)
I'm search but i find nothing, i follow this guide but nothing.
Someone can help me?
3 REPLIES 3
hadrian
Hello,
I work for NetApp on clustered Data ONTAP implementation.  That KB you linked to is the proper one to follow, so if you haven't made progress using it I suggest logging a support case so they can investigate the logs and help get the ifgrp removed.
Hadrian
Sahana
Hi,
You might be hitting bug 877418. Refer http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=877418
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
LUIGI_TAMAGNONE
I open a support case.
Thank you.
