Day-0 Command Example - Reboot a Controller
by bdave Netapp Alumni on ‎2012-06-19 04:26 PM - edited on ‎2014-09-25 03:09 PM by allison Netapp Alumni
Simple command to reboot a controller.  Implements all the same options as the 'reboot' CLI command except '-d <dump_string>'.  (All the documented options, anyway.)
I found in testing that the reboot didn't actually happen even though the command was successfully passed to OnTap via SSH and executed by the controller when I didn't use the -t MinutesToWait option.  I think this -t option is required if your controller uses CIFS, FC, or iSCSI.
I built this command because I'm using it in a workflow to activate a new load of OnTap software.
Comments and suggestions welcome!
Thanks,
Dave
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
