Day-0 Command Example - Setting SSH/SSL SecureAdmin Options
by bdave Netapp Alumni on ‎2012-05-22 08:21 AM - edited on ‎2014-09-25 02:56 PM by allison Netapp Alumni
Part of initial controller setup - Can perform any or all of the following:
  • Initialize SSH with key sizes
  • Initialize SSL with certificate settings
  • Enable SSH1, SSH2, or both
  • Enable SSL
  • Disable SSH1, SSH2, or both (and core SSH service)
  • Disable SSL
Version 2: Updated with PowerShell code fixes...  Tested this time.
Version 3: Updated with quotes around text fields of certificates in case there are spaces in names (like "North Carolina").
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
