Installing OnCommand Insight
by NetApp on ‎2013-05-20 11:30 AM - edited on ‎2015-01-22 08:56 AM by alissa Netapp Alumni
Total time: 37:06
Abstract: In this course you will recall pre-installation steps, locate installation tools, install the Insight Server and configure its initial settings, install the Insight Data Warehouse and connect it with the Insight Server.
Comments
Thanks. This was a very good quick start guide!
Trying to install OCI 7.3.1 on Widows 2012 R2, its getting failed due to Http(80) & https(443) ports are not listening
 I have been getting the same message in the logs that Http(80) & https(443) ports are not listening, have checked the ports however could not find anything.
To fix the issue tried installing IIS then the OCI installation goes fine but still unable to launch application both from Web UI and Java UI.
I have now removed the OCI and IIS from the server, still facing the same issue "Http(80) & https(443) ports are not listening"
rgds
abhay
NetApp
Hey Shakun,
Does OCI actually install, or does the installation fail, and roll back?
if it fails, you want to secure the contents of
..\sanscreen\bin\log
Before clicking any failure popups
Matt
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
