Run workflow from powershell using webservices
by Occasional Contributor on ‎2013-04-03 11:23 AM - edited on ‎2014-09-25 03:51 PM by allison Former NetApp Employee
.SYNOPSIS
   Calls a workflow from WFA
   Input is detected automatically
.VERSION
   2013-02-04
# DATE: 04/02/2013
# AUTHOR: Mirko Van Colen
# variables
$username = "Username"
$password = "Password"
$wfaserver = "127.0.0.1"
$uri = "http://$wfaserver/wfa-ws/WorkflowService_rpc?wsdl"
$parameters = @()
#$VerbosePreference = "continue"
# create credentials
Write-Verbose "Creating credentials"
$cred = New-Object System.Management.Automation.PSCredential -ArgumentList @($username,(ConvertTo-SecureString -String $password -AsPlainText -Force))
# fire up the webservice
Write-Verbose "Connect to webservice $uri"
$wfa = New-WebServiceProxy -Uri $uri -Credential $cred
# get list of workflows
Write-Verbose "Get the workflows"
$workflows = $wfa.getAllWorkflows()
# list them up
Write-Output "Pick a workflow"
Write-Output "==============="
$workflowIds = @() # build a valid workflowid array
foreach($workflow in $workflows){
    $workflowIds += $workflow.id
    Write-Output "$($workflow.id) : $($workflow.name)"
# prompt for workflow id with error checking
do{
    $workflowId = read-host "Enter a valid Workflow-id you want to start"
while($workflowIds -notcontains $workflowId)
# get chosen workflow
Write-Verbose "Get workflow $workflowid"
$workflow = $workflows | where{$_.id -eq $workflowId}
# get user input
Write-Verbose "Extract userput fields"
$userinputFields = $workflow | select -ExpandProperty userinput
foreach($field in $userinputFields){
    $input = ""
    $validationString = ""
    Do{
        Write-Output "-----------------------------------"
        # description
        if($field.description){
            Write-Output "Description : $($field.description)"
        # validation presentation
        if($field.value){
                $validationString = $field.value
                # visualize Enum with "|"
                if($field.type -eq "Enum"){
                    $validationString = "[" + ($field.value -join "|") + "]"
                Write-Output "Validation : $validationString"
        # get default value if any
        if($field.defaultValue){
            $defaultValue = " [$($field.defaultValue)]"
        }else{
            $defaultValue = ""
        # read the input
        $input = read-host "$($field.name)$defaultValue"
        # set the default value
        if((-not $input) -and $field.defaultValue){
            Write-Verbose "No input given : defaulting the value to $($field.defaultValue)"
            $input = $field.defaultValue
        # validate the input
        # default = true
        $validation = $true
        # only validation if value is given
        if($field.value){
            # number - scan the range
            if($field.type -eq "Number"){
                $range = $validationString -split "-"
                $input = [Int32]$input
                $lowest = [Int32]$range[0].Trim()
                $highest = [Int32]$range[1].Trim()
                $validation = (($input -ge $lowest) -and ($input -le $highest))
                Write-Verbose "Validated number $input as $validation between $lowest and $highest"
            # enumeration - check the array
                $validation = $field.value -contains $input
                Write-Verbose "Validated enumeration $input as $validation in array {$($field.value -join ",")}"
            # string - check the regex
            if($field.type -eq "String"){
                # we change the regex a bit (^ & $) to get it working
                $validation = $input -match "^$validationString$"
                Write-Verbose "Validated string $input as $validation against regex /$validationString/"
    }while(-not $validation)
    Write-Verbose "Adding parameters : $($field.name)=$input"
    $parameters += "$($field.name)=$input"
# lauch the workflow
Write-Verbose "Launching the workflow $($workflow.id) with parameters $parameters"
$jobid = $wfa.executeWorkflow($workflow.id,$parameters)
# monitor job status
do{
    $status = $wfa.getJobStatus($jobid)
    Write-Output "Workflow status : $($status.jobStatus1)..."
    Write-Verbose "Sleeping 2 seconds"
    Start-Sleep 2
while($status.jobStatus1 -ne "COMPLETED")
Write-Verbose "Job completed"
write-output "returning parameters through the job status"
foreach($param in $status.returnParameter){
    write-output "$($param.name) = $($param.value)"
write-output "returning parameters through webservice"
foreach($param in $workflow.returnParameters){
    $returnedParameter = $wfa.getReturnParameters($jobid,$param.name)
    write-output "$($returnedParameter[0].name) = $($returnedParameter[0].value)"
$stop = Read-Host 'job finished... press enter to stop'
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
