Vfiler deployment with root and data vol and qtree - Workflow Example
by NetApp on ‎2012-06-28 02:08 AM - edited on ‎2014-09-25 03:11 PM by allison Netapp Alumni
This workflow creates a root, data and audit vol. Then a vfiler is created with the volumes and a qtree from the audit vol.
WFA Version 1.1.1.22.5
Prereq's:
A vfiler in the ipspace already exists so the interface is already configured with an ipadress. The vfiler create command adds the new vfiler already with an alias on the existing interface. To achieve this the certified vfiler create and configure command had to be updated. If you already have the ipspace and interface assigned to it the certified command throws an error and the workflow stops. The error message commes from the api call "interface assignment only partially successful. I changed the command to vfiler create and configure custom. In the section for the ipspace the assignment of interfaces to the ipspace only takes place when the ipspace is created within that workflow.
There will be room for improvement so any ideas are appreciated.
Thanks
Stefan
Comments
NetApp
Stefan,
This is great stuff.... thanks so much for sharing!
-Kevin Hill
WFA Team
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
