WFA release document - WFA installation and setup guide
by NetApp on ‎2012-03-04 05:04 AM - edited on ‎2014-09-25 01:29 PM by allison Netapp Alumni
This is the document thread for the WFA installation and setup guide.
Every updated document will be uploaded to this document thread to create a version respository.
Document revision 1.7 - Updated post WFA 1.1 release
Revision changes
  1. “Appendix E – Configuring WFA to VCENTER Connection” (p.33) – Add more detail on Registry Key when Using Registry Option in Setting Authentication Mode of VC SQL Server to Mixed Mode
  2. “Appendix B – Upgrading WFA” (p.19) – Removed reference to “Configuration Only” option in backup.
  3. “Appendix A – Installation kit checklist ” (p.19) – Updated WFA license section to refer to the license portal, instead of a dl.
  4. "Appendix D - Automated OnCommand 5 setup" - Updated description and location of oc5setup package within WFA installation
Comments
NetApp
Great Document, for the dfm db acces it would be great to have a description to create the user instead of using the script. Had problems to run it:
Verifying archive integrity... All good.
Uncompressing WFA OnCommand-5 Setup...
./setup.sh: line 4: /java/bin/java: No such file or directory
My customer wants to document what users have access and which capability is needed.
e.d. the commands dfm database user create ... role definition etc.
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
