Workflow Example: Vol move - c-mode
by NetApp on ‎2012-06-18 06:44 AM
This workflow allows the user to select a volume to move to another aggregate in a c-mode cluster.  This workflow is very straightforward and it has a couple of other capabilities in it that can be useful as examples for other workflows:
New Commands:
  • Move CM  Volume - new: Initiates the vol move job on the cluster
  • Wait for Move CM Volume - new: Waits for the vol move job on the cluster to complete
User Inputs:
  • All inputs are 'locked'
  • Select from the available Clusters in your environment (pulled from an OC UM 5.0 or 5.1 datasource)
  • Select the available vServers in the selected cluster
  • Select a volume in the identified vServer
  • Select the aggregate to move to by:
    • aggr name
    • Aggr available capacity
    • Sorted by most available capacity
  • Screenshot:
WFA: 1.1.0.53.2 B6510
Hope you find this useful!
Warning!
This NetApp Community is public and open website that is indexed by search engines such as Google. Participation in the NetApp Community is voluntary. All content posted on the NetApp Community is publicly viewable and available. This includes the rich text editor which is not encrypted for https.
In accordance to our Code of Conduct and Community Terms of Use DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information
  • Copyrighted materials without the permission of the copyright owner
Files and content that do not abide by the Community Terms of Use or Code of Conduct will be removed. Continued non-compliance may result in NetApp Community account restrictions or termination.
