I have a workflow that creates a primary volume, a secondary volume and a snapmirror relationship and then use the Add volume to dataset command to put the volume into an existing dataset.
The workflow works in preview mode but fails on execution
The dataset has a protection policy attached and if I import an existing SM relationship it works fine.
When adding the volume to the dataset I get the following error.
Error: Could not add EUKSBNETAPP02.endemoluk:/Arch_DanTest1115 to dataset EUK_Archive (4324). Reason: There is no volume, qtree, directory, host, aggregate or virtualization object named 'EUKSBNETAPP02.endemoluk:/Arch_DanTest1115'.
The volume does get created, so it does exist.
Has anyone come across this before, or know where I can find additional info on the error to help troubleshoot
Regards,
