BMC problem connecting to FilerView / System Manager
transferex
Hi,
I have a problem, I recently downloaded the software OnCommand System Manager, but do not get it to work, not really get it to work the BMC connection via HTTP or SNMP in any way. I rebooted the BMC console dede I checked its configuration, HTTP mode ison, the ip responds to ping, (SSH is off) I connected directly to the FAS2020 by ethernetto rule out problems with the switch but either.
You do not say this is the first time I try to connect via http to the cabin to manage,
Thanks,
Regards
20 REPLIES 20
