Subscribe
Highlighted
C-Dot Volume Comment Field
Before I bug Jeremy directly, I figured I would ask here.  Anyone know where/how to use WFA to fill out the comment option for C-Dot volumes?  None of the create or modify fields cover comment.  Running 2.2.0.2.6
Re: C-Dot Volume Comment Field
All WFA cDOT Modify commands have been updated to add the the "Comment" field. They will be available the the future WFA releases. You can clone the certified command and make this modification. It should be simple.
I can provide the code if you want it..
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Sinha,
I would appreciate that. If its NDA you can send to my netapp address david.blackwell@netapp.com.
David
Sinhaa,
Still waiting for that code to import in if you could.
David
I had sent it long back to your mail id. Okay sending it again.
Sinha, can you please share the code to add comments to the standard functions.
Thanks!
Colin
I'm running WFA 3.0.0.0.2P2, and I dont seem to see any filters or finders related to a volume comment field. Can you share the code please, or the SQL query?
[ Edited ]
Sinhaa could you please email me the code to update datasource to include collecting the comment field.
Thanks!
