Disable snapshot on netapp C mdoe volume using powershell commands
CAPATEL_NET1984
I was looking for command to disable snapshot on a volume but not able to find an option in netapp PS toolkit.
is there a command or options in cmdlet i can set to disable the snapshots on a particular vol?
1 ACCEPTED SOLUTION
asulliva
Hello @CAPATEL_NET1984,
There are two ways you can disable snapshots:
  1. Set the snapshot policy to "none"
  2. Set the volume option "nosnap" to "on"
To change the policy, you can use this PowerShell:
Update-NcVol -Query @{ Name = $volName } -Attributes @{ VolumeSnapshotAttributes = @{ SnapshotPolicy = "none" } }
To disable the volume option:
Get-NcVol $volName | Set-NcVolOption -Key nosnap -Value on
You can read more about PSTK + snapshots here and volumes here.
Hope that helps!
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
5 REPLIES 5
asulliva
Hope that helps!
Andrew
CAPATEL_NET1984
Tried in WFA
erro is below
09:58:18.167 ERROR  [LM Disable snapshot for backup volume] Failed executing command. Exception: Modification of the following fields: auto-snapshots-enabled not allowed for volumes of the type "Flexible Volume - Read-Write volume".
param (
        [parameter(Mandatory=$true, HelpMessage="Cluster IP address")]
        [string]$Cluster,
        [parameter(Mandatory=$true, HelpMessage="Volume name")]
        [string]$VolumeName,
        [parameter(Mandatory=$true, HelpMessage="Storage Virtual Machine name")]
        [string]$VserverName
        # connect to controller
        Connect-WfaCluster $Cluster
        #testing volume existence. this command somehow doesn't throw exception if
        # ErrorAction is 'Stop' and the volume isn't found. adding if block
        $vol = Get-NcVol -Name $VolumeName -Vserver $VserverName
        if(!$vol)
        throw "Volume '$VolumeName' not found on Storage Virtual Machine '$VserverName'"
Get-WFALogger -Info -message $("Modifying volume: " + $VolumeName + " on Storage Virtual Machine " + $VserverName)
$status = Get-NcVol $VolumeName | Set-NcVolOption -Key nosnap -Value on
#$status = Update-NcVol -Query $queryTemplate -Attributes $attributeTemplate -FlexGroupVolume
        if($status.FailureCount -eq 1)
        throw $status.FailureList[0].ErrorMessage
CAPATEL_NET1984
taht query of setting it to none worked, but when i chnage the snapshot policy directly to none in create volume command's inputs in wfa it does not work
so I can use another powershell command to set none as SS policy on a volume but i can not use the wfa create volume certified command's in put name snapshot policy and can not set as nonw
CAPATEL_NET1984
also I ahve differnt code version in lab and prod and i noticed that on older code version 9.1p1 i need to do below, added -FlexGroupVolume:$false and it worekd fine
i did not added this on 9.2 version and it still worked
Update-NcVol -Query @{ Name = $VolumeName } -Attributes @{ VolumeSnapshotAttributes = @{ SnapshotPolicy = "none" } } -FlexGroupVolume:$false
geringer
Take a look at get-ncvol and update-ncvol.  I think the volume attribute you want to update is .NoSnap.  This could also be the option to enable user access to teh snapshot directory, so you will want to test this.  Look at the Example at the end of
get-Help Update-NcVol -full   for an example of how to do this.
